YesCan you attach the camera to the pano roof?
Long story short I have a Thinkware dash cam but I forgot to disable the impact setting so every time I hit the apex it switched to impact mode and dropped the file in a different folder so the video was useless.
Unfortunately Homestead is the only track Teslas can use due to the lack of Supercharges You need to recharge every second run (third if you push it) and thats with a P100 a 75 will probably make two runs.
They have 20+ 240v 40 amp hook ups in the paddock but they will not charge you fast enough
The Homestead SC is only 5 miles from the track so you have time between runs to replenish the batteries WPB and Daytona SC are too far from the tracks.
That said I would encourage anyone who dont mind the drive to Homestead to come try a track day.
It is safer than I95 you can even get an instructor to drive with you if you feel nervous but believe me after two runs you want to be on your own.
Its is a real adrenaline rush throwing your car into the corners and passing everyone in the first 2 laps
On that point passing is strictly controlled in the novice class you can only pass on the straight and you must get a hand signal from the guy in front to pass left or right of him (See when I pass the vet)
And even if you do make a mistake (As I did) you can see it is an easy out.
This time I saw a lot of high end cars on the track Lambo Ferrari AMG SLS Mercs Porsche even a Mclaren they are not out to damage their daily drivers
Next Track day March 17th
