Peak Oil
Discussion in 'Energy, Environment, and Policy' started by tonybelding, Sep 17, 2007.
  1. tonybelding
    tonybelding Active Member
    Hamilton, Texas
  2. vfx
    vfx Well-Known Member
    CA CA
    #2 vfx, Jan 15, 2009
  3. vfx
    CA CA
  4. vfx
    CA CA
  5. vfx
    CA CA
    #6 vfx, Mar 28, 2010
  6. TEG
    TEG TMC Moderator
  7. TEG
    TEG TMC Moderator
  8. jaanton
    jaanton Roadster NA #1026
    Oakland, CA
    reverse oil war
    Consider an oil war where the agreement is that the Saudi's and the rest of the world agree to keep using oil until it runs out at about the same time. From a supply/demand perspective, neither wants to run out first because running out means you are at the mercy of the other.
  9. kgb
    kgb Member
    Houston, TX
    Hard to tell if this is a parody or mental illness. There was so much oil in this presentation that Jesus was drenched in it!
  10. vfx
    CA CA
    Consider the source.
    They might be cooking the books to back up their demand for more deep water, national park, and shale operations.
  11. Alfred
    Alfred Supporting Member
    Zurich
    How much there is underground is currently not decisive. In the short to medium term there is probably just not enough production capacity in relation to anticipated demand. It is not possible to expand production significantly at short notice. In economic language: Supply is inelastic. Apart from the question whether you would like to blow all those reserves into the atmosphere, a peak oil situation could therefore emerge over the medium term, regardless of all other good or not so good intentions. The details of this are well explained in the following (voluminous) study:
    http://www.odac-info.org/sites/default/files/The%20Peak%20Oil%20Market.pdf
  12. vfx
    CA CA
    Good writeup.
    http://www.chrismartenson.com/crashcourse/chapter-17a-peak-oil
  13. vfx
    CA CA
    http://www.theoildrum.com/node/6169
  14. cinergi
    cinergi Active Member
    MA
    ... assuming the same source-to-wheel efficiency, sure. Charging BEVs to travel as many miles as ICE vehicles requires less (how much? I'm sure someone here knows) energy.
  15. SByer
    SByer '08 #383
    Cupertino, CA
    2000x for alternative energy sources sounds like a lot until you realize that it doesn't take that long if you have a healthy CAGR. It's 30 years at 30% annual growth - 30% is what wind power grew by globally in 2010. China is investing enough in alternative energy to make that reasonably attainable.
    No, not going to be fun getting there, but it doesn't mean we can't. To bad the US isn't planning ahead or investing enough in the future. Actually, just phase out subsidies on oil and coal and I bet the free market would take care of most of the rest.
  16. Alfred
    Zurich
    A modern nuclear station might be sized to around 1500 MW and could produce then 13 TWh/y.
    10 million b/d correspond to 500 million tons of oil per year. Taking that as an energy equivalent, with one ton of oil equivalent holding 11.7 MWh, we get an annual call for 5850 TWh, or what 450 of those stations could produce. If used only for road transport, considering efficiency, you would end up with on the order of 45 new stations. This is still too high of course, because crude oil has to be refined and not all of it can be stuffed into cars. So at the most 20 new mid-sized station or perhaps 10 larger ones are closer to reality.
    Further details about such estimates can be found on my pages.
