My fans and HID lights were installed today. For some reason the car (well really the laptop) decided to be cantankerous about the bleed test, so that took a bit of extra time. Installing the HID lamps took quite a bit longer than the fan install, and most of that time was spent getting the wheel liners out (I have the older plastic ones, which are more trouble). Probably didn't help that he was doing it on the floor of my garage. Altogether everything took almost 7 hours.
The first picture shows the modified sway bar going around the newly installed motor assembly.
The reason they need to cut out four studs is that there were originally eight, to hold in two separate fan units. The center four studs would end up being in the middle of the motor, so they have to go. They have a rather noisy tool that cuts through them like butter - took only a couple of minutes to do all of them.
The orange colored bar along the bottom is a rubber piece. It forms a seal, but also moves the bottom panel of the car downwards just a hair to make a little more room for the fan assembly. I suppose this reduces ground clearance very slightly in the rear, but I doubt you'd ever notice... besides, the car always bottoms out at the front first. :redface:
The motor assembly is mounted on a pretty solid looking aluminum panel, and is attached with small spacers. Once the motor assembly is installed, a shell is placed around it. There are different versions of the shell for 2.0 and 2.5 cars.
The same bolts that hold the sway bar also hold the shell, which extends all the way down to the bottom panel, where there are rubber seals. Air enters a gap around the top of the box. Junk swirling around under the car doesn't make it up that high, so it keeps away from the fans.
The new motor is better sealed, and it is quite a bit larger than the original motors. There are very large impellers on either side, one for the traction motor and one for the PEM. They deliver quite a bit more air than the original fans, but are a bit noisier.
Both of the original fan cables are connected into a single Y cable. There are diodes in the lines, so if the car powers up either the PEM fan wire or the motor fan wire, the single motor gets the power and spins.
