Go around, you won’t be doing a burnout.Are y’all driving around the box or thru it? I’m used to driving around in awd but dragtimes always does his little pull thru it. Going to Pueblo on fri night for some actual 1/4mi in the LR
Always drive around it.Are y’all driving around the box or thru it? I’m used to driving around in awd but dragtimes always does his little pull thru it. Going to Pueblo on fri night for some actual 1/4mi in the LR
Head's-up, as far as I know the drag strip is closed for the season due to the surface being trash. I just checked the website and there are 0 events scheduled there.Are y’all driving around the box or thru it? I’m used to driving around in awd but dragtimes always does his little pull thru it. Going to Pueblo on fri night for some actual 1/4mi in the LR
Yeah they got it fixed thankfullyHead's-up, as far as I know the drag strip is closed for the season due to the surface being trash. I just checked the website and there are 0 events scheduled there.
I’ve gotten it down to a 10.61 at 129 and a few 10.8s. I want that 10.5 but I doubt it’s gunna happenThat’s hauling ass for an LR
I’m on the 19s actually that’s just an old photoIf you were running 19's you would probably get it... From your profile pictures you are on the 21's that are heavy as F***
On a Plaid 19's vs 21's is worth 2-3tenth
That would be a riot haha it would be a low 10s car right out of the box. I’m not sure what others have run with the LR but the fastest I’ve seen on yt was a 10.869 or so by a guy in Houston.What’s crazy is that the LR is neutered down low by Tesla. They need to uncork it, probable gain a few tenths
My 3 best passes of the night, all in the 10.6s and yes you can trap 130mph in a LR in Pueblo. No launch control used at all no weight reduction. Honestly still mind blown it was this quick. With the passenger seat out and the rear seats out I’m betting I can get this into the 10.2-10.3 range. I’m 190lbs I’ve got some video that I’ll be throwing together
I def think pulling 100-200lbs of interior out of the car should net me a couple 10ths if I can get a 10.61 with nothing removed.Yeah, 10.5 is possible if you can remove the seats. Not going to say a 10.2 or 10.3 is possible, but definitely into the 10.5x
The ancient generic way we looked at it was that 100 pounds = .1 but EVs are a different monster, so that assumption no longer applies.I def think pulling 100-200lbs of interior out of the car should net me a couple 10ths if I can get a 10.61 with nothing removed.
So I saw Wallace racing but it’s not very accurate at all. Do you know of another way to back calculate a rough 0-60 based on 60’ and some other metric? I didn’t have a draggy but I would figure I’d be below the rated 3.1 but wasn’t sure. Even taking into account a few 10ths. Problem is the power curve for this calculator it’s basing off 1/8th mph and time. Anything around a 2.5 would still be stupidly fast and way under ratings from Tesla and this is showing a 2.2The ancient generic way we looked at it was that 100 pounds = .1 but EVs are a different monster, so that assumption no longer applies.
200 pounds may get you .2 - .3 if the car was running 11.xx but the faster you are, the harder it is to get that .1 additional reduction.
And remember this is talking about consistent numbers, not a one-off.
This goes back to the EV being a different animal. Almost all of the calculators and estimates went out the window with the power delivery dynamics that Teslas haveSo I saw Wallace racing but it’s not very accurate at all. Do you know of another way to back calculate a rough 0-60 based on 60’ and some other metric? I didn’t have a draggy but I would figure I’d be below the rated 3.1 but wasn’t sure. Even taking into account a few 10ths. Problem is the power curve for this calculator it’s basing off 1/8th mph and time. Anything around a 2.5 would still be stupidly fast and way under ratings from Tesla and this is showing a 2.2View attachment 1054756
EVs won’t defy physics. I believe the issue is the computer cutting power. A gutted plaid only running a few tenths faster than stock doesn’t make sense even accounting for its power curve versus ICE. Once we get more hacking of the ecu i expect to see low 8sec plaids
