sorka
Not to derail this thread but it won’t be hard to guess the 3 people who voted no, they are the same people who continuously back tesla regardless of the facts.
Yup, most of us know exactly the three.
I’m sure this is a silly question. BUT isn’t an axle seal not connected to the DU? I had my front axle seals replaced under warranty when I had the death rattle fixed a few weeks ago. (I am however still under the warranty period)
It is, but more importantly, is shown by engineering data, DWG/PL, to be part of the DU. Seals are not part of the drive shaft or any other part of the car. If you order a DU, it will come with seals. If the seals fail, the are covered under the drive train warranty which includes the DU.I’m sure this is a silly question. BUT isn’t an axle seal not connected to the DU? I had my front axle seals replaced under warranty when I had the death rattle fixed a few weeks ago. (I am however still under the warranty period)
Columbus SC thinks it’s the battery heater. Thoughts?
Got it back from service was solid until I hit the slightest bump. Had to go back, explained rear felt loose they chuckled and we went for a test drive. Techs face was red after a few bumps and went back in to find they didn’t bolt the stabilizer link down. Woke up this morning in the cold, got warnings that car may need service and acceleration and top speed reduced. Last night saw it said low voltage for a split second. Today when backing out of a parking spot drive beeped and would not go. Put in park and tried again and it worked. Columbus SC thinks it’s the battery heater. Thoughts?
Are you referring to the 3 people here who would somehow justify and make excuses if the drivetrain warranty started excluding the actual drivetrain?
I recently had the "Car needs service...," "Acceleration and top speed reduced," and "Regenerative braking system disabled." I limped it to my local SC and the logs indicated that I needed to replace the drive unit, HV contactors, HVAC drain hose, and they replaced the 12V all under warranty.
Car is a Nov 2013 built S85 w/ 88K miles on it. Bought it in Jan 2019 w/ 59K miles on it and I'm grateful for the warranty. Both the drive unit and contactors were the original and both parts have been revised over the years, so I'm hoping this won't be a reoccurring issue for at least another 6-12 years...I'm sure there will be other issues though.
A bit off topic but good to know the 12V batteries are covered under warranty.
Does the ESA cover the 12V battery as well? I guess the ESA deductible would make that a bit moot unless you combine that visit with other issues.
Was it a pump seal for the transmission or the rear main seal on the engine
Hi, I got a "Acceleration reduced" warning light.
my 2013 MS with 48,300 miles is scheduled for service at Augorahills,CA. They sent me an invoice for $1200, in it they have mentioned the need to replace contactors and pyro fuse in the hv battery. My question is, did you have to pay for your service to get the contactors replaced. I thought the battery warranty is for 8 yrs. Please advise and thanks !
