I have a Y LR 2023, 6300 miles, and just did a long freeway drive using FSD Beta 11.3.6. I am a glider pilot, and as such I think that the attention alert system Tesla uses is poorly conceived and hazardous. Pilots are taught to scan, scan, scan for hazards. But making the alert you are required to quickly respond to, appear as a small blue text notice in the lower left side of the screen forces you to frequently take your eyes off the road ahead, and drop them to where this appears when it does (about once a minute) lest you miss it. That is unnecessarily unsafe. Yes, if not responded to, it then escalates to flashing blue at the top of the screen, which is better (and should be the first warning). However, you then have very little time to respond before it disconnects and gives you one of the 5 dings prior to disconnecting FSD for two months. If there was a heads-up display, it would work better. But at the very least, it should appear at the top left, and allow you to turn on an audio beep with the first display as a settings option. Do better, Tesla!
