montgom626
It may take them awhile but so far, they've delivered on all promised items except for the lighted vanity mirror.
You are right. I must be patient.
..and the sunshade for the pano roof
..and WiFi
..and onboard storage for music
..and foglights
but I still trust that they will deliver.
what's the holdup on wifi, anyone heard anything on this front?
also, quick data point. i'm out of town and my car is hanging in the garage, i had to remotely (my brother) install v4.5 so i could use the charge level slider to set the car to ~50%. that's done and i've been tracking the slow charge bleed as it gets down to 50 from its usual/former 93% standard charge, and i thought i'd point out that the drain i'm seeing isn't as bad as what it used to be. i was getting about a mile an hour in overnight drain, so close to 24 miles in a day -- the last three days i've checked it's doing about 8 miles in a 24 hour period. much better. i am in socal, so no temperature challenges to speak of, but even so.. a big difference from what i was seeing a month or two ago. do others have this experience?
My MS loses 3KW a day. I can get 3-4 miles from each kW. So, I use/lose a minimum of 1095 kW per year. Or 3200 to 4300 miles a year are lost from doing nothing more than just sitting. I only drive 6000-8000 miles a year. So half of my energy use is lost. Equal to charging my MS 12 times with nothing to show for it.
I am hopeful that TMC can fix this vampire loss sooner rather than later.
so with that loss you are out about $72 dollars a year on electricity Do you have a 60 or 85 ? Have you reached out to tesla service regarding this? If so what was there response?
At .15/KWh (loaded rate with transmission charges, generation charges, meter charge, customer charge etc), it's more like $164/year in my area. That's not the big issue though; the larger problem is, you park your Model S at long term airport parking, not plugged into an EVSE, you go away for a month, your car is nearly discharged, probably unable to get you home. That's not a great scenario, and it's one issue you don't have with an ICE. They need to get the vampire load reduced significantly for the Model S to be considered "as good as an ICE", so far, "fail" on this issue.
