Problems opening the charge port with the home cord button
CEFX2018
6
0
Durham, NC
I have had my X for over a year and recently it has started being fickle about whether the button will open the charge port. I don't know if there was a software change. Sometimes it opens the way it should and other times I have to use my app to open the door. Opening the lift gate when I park seems to be one of the triggers. The charge port will not open even if the gate has been closed before I press the charge cord button. This never used to be a problem. Is anyone else having this problem? Any suggestions on how to fix it?
I have tried messaging with Tesla and they told me to contact my local office. I left a message at the local office and it has not been returned in over a week. I don't know how Tesla expects to survive with such pathetic service. I should not have to go to a blog to get help.
Thanks!
posity
185
330
Southern Oregon
You will find many threads here discussing this problem. 2019.8.6 seems to have fixed the problem for most people. So you probably just need to wait until a new software version is pushed to your car that fixes the problem. In the meantime, you can push on the front edge of the door to open it manually.
Mr. Ed
65
70
Running 2018.5 and had no problem opening the charge door pushing the button on the charge cord in my garage a few hours ago
nanimac
Aloha!
Nov 27, 2012
2,428
570
Oahu
Anyone have issues with charge port opening by itself? When I close it manually and get in the car, it opens again. :mad: It only closes when I put the car in reverse. My seat also goes to my driver setting like usual but then goes back to easy entry. I've rebooted 3 times and still not working right. Hopefully update will fix it.
Advocacher
12
13
Bowen Island, BC
This happened to us after our key fob got soaked. If your key fob is not new perhaps consider replacing the battery?
bob_p
3,691
2,802
This seems to be an intermittent problem with the recent software updates. Sometimes it works - and sometimes we open the charge port manually by pushing on it.
It was reliable prior to the recent software updates.
Malbrough
89
111
Oklahoma
Good to know. I also got the same problem as the OP introduced on 2019.8.5 along with other issues like radio functions delayed and rear camera freezing. Waiting for the next update to see if that fixes things.
NigelM
Recovering Member
Apr 3, 2011
13,386
555
Northern Virginia
Did have this appear recently but during one of the subsequent updates it seems to have been fixed again. Currently running 2019.12.1 but installing yet another version tonight.
P.S. IIRC the receiving antenna is in the trunk area so pointing the charger handle at the rear window as you press the button may help with opening the charge port
Reactions: DCGOO and nanimac
LTR2018
83
49
Had this issue appear with 2019 updates.
Just got 2019.12.11. We will see if they've fixed this problem.
Definitely software. Prior to first 2019 update, never happened.
