So far I've been charging on a 120 volt 15 amp gfi circuit in my garage. That works ok for my daily needs, but the gfi trips about 50% of the time when the garage door opener is used. Nothing else is on the circuit, unless I'm playing with tools.
Its hard to expand to a 50 amp dedicated circuit because the breaker box is physically full, although well below the 200 amp service. It turns out that the garage circuit is on a 20 amp breaker and has 12 gauge wire, but the outlets are all 5-15s.
So I wonder as a quick and simple (i.e. within my skill set) change can I splice in a 5-20 outlet between the box and the gfi outlet so as to pull 18 amps for charging without the circuit gfi, or would that be something irredeemably stupid and against code ? Around here anyway no need for a permit or inspection for this change.
As an aside the whole structure will be remodeled over the winter and I'll have a dedicated wall charger (or two) added, so this is temporary, but would be a nice increase in charging speed and convenience for the next 8 months.
