Should I be worried about the seal for the battery? The plastic trim as seen in the pictures is bulging out a bit.Clear liquid is almost certainly just condensation from the AC system. If it was greenish/blueish it could be coolant. If it's light blue it's w/s washer fluid.
Theoretically possible to damage a coolant line, but they're tucked really far up and in. I don't think a low speed curb would get anywhere near that.
So I shouldn't worry about water getting into the bulge from that trim piece if it's raining or if I go through a puddle?Doubt you have to worry about the battery. They are much tougher than that. All of that is superficial body trims.
if you are worried about water getting INTO the battery pack, no, don't worry. Water's going to get in there, it probably already does anyway. That's just a body trim piece. But you should avoid puddles anyway, regardless of this cracked rocker panel.So I shouldn't worry about water getting into the bulge from that trim piece if it's raining or if I go through a puddle?
They seem to be pretty far up there based on that. Surely that's not it?Graphics of the coolant and brake lines in that side rocker panel area.
Brake Lines
Coolant Lines
Agree but you will have to be the judge on that. Couldn’t tell how big your hit is from your pictures.They seem to be pretty far up there based on that. Surely that's not it?
Not entirely sure. Just went out to it and it was dry in that area I belive. Stuck my hand under and didn't feel anything wet.Here’s another view of brake line (w/ red colored mounts) behind the side skirt. This is with battery removed so yeah maybe 3-4 inches up?
Just wondering why your side skirt was wet..
Right. Earlier it looked clear when I tried that. Just worried about the cost to fix all this and the nearest service center is around 2 hours away.The rocker area doesn't seal anything, so no issues. The rest looks like water condensate, but put a white paper towel under to catch it, to see if there's any color that might indicate it's something besides water.
Is it really that expensive? I'm very surprised that much goes into it....wouldn't worry about coolant or brake lines if the liquid is clear. however that dented rocker panel won't be cheap to fix... it's not a part which can be readily replaced without major bodywork and welding + painting. would be surprised if it can be fixed for less than $5k.
It looks like a simple fix? | Teslawouldn't worry about coolant or brake lines if the liquid is clear. however that dented rocker panel won't be cheap to fix... it's not a part which can be readily replaced without major bodywork and welding + painting. would be surprised if it can be fixed for less than $5k.
That's the plastic bottom part. The metal part is what he was talking about. It's expensive/involved enough that some people just buy some aftermarket side skirts to cover it up.It looks like a simple fix? | Tesla
correct. cracked rocker panel plastic covers are ~$200 / cover from the SC and you can install yourself. the dented actual rocker panel is metal and part of the entire frame. dumb design and cost prohibitive to fix in most cases imho.That's the plastic bottom part. The metal part is what he was talking about. It's expensive/involved enough that some people just buy some aftermarket side skirts to cover it up.
Unlike the Model Y, the metal part is part of the body (go from the rear quarter panel to the metal rocker, you will see it is one continuous piece). So it requires cutting and welding for a "proper" repair. Other less expensive methods may be body filler or if it is minor enough perhaps PDR, but that's not the "proper" method for replacement.
