I started seeing some weird small little flakes on the rubber seal of the rear left passenger window.
First it was just one, that I pulled, and now, 1-2 weeks later, 3 more appeared
I double checked the door and the window is being lowered as the door is opened and raised as it is closed, just as it should.
Is this any sign of worry, or is it just a small issue that the rubber seal is a mm or two within the play of the window as the door is opened/closed and it shaved it in the process and problem will "fix itself"?.
