I have a 2014 (Nov build) Model S85 (w/ AP1). I've had this intermittent issue where the rear driver's side door would not open when you pull on the inside door latch/handle. To open the door, I would need to open it from the outside door handle. (I made sure that the child protection lock setting was not on in the UI settings.)
Does anyone know what issue this could be where the inside door latch will not open the door (but it can be opened from the outside)? Looking at the various forums post, the rear doors handles are electronically connected to the door latch (unlike the front doors where there is a mechanical connection is you pull far enough). Since I can open the door from the outside, I don't think it's a door latch mechanism issue.
If anyone have any insights, I'd greatly appreciate it!
