Breaking off a topic from the tankless water heaters topic over in the environment section of this forum. This isn't Tesla energy specific exactly but I wanted to catch the attention of the master electricians roaming this little section of TMC.
Anyway, I was sharing how my panel was nearly maxed out capacity wise - plenty of spaces in a new panel but only 125A service (which would be mega bucks to upgrade) and I was concerned I wouldn't be able to stuff a water heater circuit (240V/30A or 15A depending on model) if I eventually wanted to get a heat pump hot water heater (house is nearly all gas appliances). I showed the standard load calc which put me at 7A (corrected later to ~9A) under the 125A limit, and then showed my worksheet to prove how few amps I had left.
I then did a rough "alternate method" calc which showed I had 28A to spare and would be ok even if I did add the 30A circuit using the alternate method.
I'm quite surprised by the difference these two methods calculate. Is this just the way things are? Is the alternate method nearly always the way to go?
Here's the posts with the load calcs themselves:
Tankless water heaters are terrible....
As an aside, I find the replies further down the thread that "I just need to switch to LED lights" particularly humorous. I of course have already done so, but that doesn't change code.
