Sorry for the late response. The one that worked for me was Ford part no. AM64-19D623-AB. Get as high of serial number as you can as higher = Newer
Replacement is a royal pain as you basically need to remove everything from the front area to get to it. Make sure you fill with Freon and the proper oil that is MADE for EV’s or you risk damaging compressor and risk of shock due to conductivity of normal AC oils and leak detection dyes. Have fun!
