He made the point in this video that hydrogen can be made from water with renewable energy, which is true. ....
I suspect that Llewellyn is constrained a bit. If he criticizes too much, he loses access. Companies allow him to review their cars for publicity after all.
Exactly.For how many years has he been berating FC, then gets in one and is like a different person. He wasn't just neutral, he was actively praising it.
True, but it takes about four times as much renewable energy to make hydrogen for a fuel cell car as it takes to charge up a BEV to travel the same distance. Not to mention other issues, like lack of home refueling.
GSP
I should have been more precise, I was referring to praising the idea of FCVs. He puts forth the argument of wind turbines at service stations enabling hydrogen generation and refuelling at them, he doesn't then balance it about hydrogen from natural gas etc.
I just think more people will be pro-FCVs than before after watching it. Is that wrong? Well it depends if people are anti-BEVs as a result.
I agree with you about the skimming through the Mirai, I can't even recall features it has or dashboard.
Not ignorant at all. Look under the hood of the the Leaf, or the i3...there's a lot of "stuff" that isn't an engine in there! Even the Model S looks pretty crowded when you remove the frunk cover. Master brake cylinder, ABS controller, washer, power electronics, radiators, HVAC components, vacuum pump, power steering motors, etc. The batteries, tanks, and fuel cell stack aren't even in the front of the Mirai...they are under the seats.I expect this is a very ignorant question, but why so much "stuff" under the bonnet? (Video @ 0:54 )
If you are comparing the front compartment of a Leaf or i3 to the Model S, keep in mind that the S is a much bigger car and has more room to place the items that Woof lists. The result is this the S has a capacious "frunk" and the other EVs do not.I expect this is a very ignorant question, but why so much "stuff" under the bonnet? (Video @ 0:54 )
... fuel cell stack aren't even in the front of the Mirai...they are under the seats.
That flat laptop sized thing is the power control unit, similar to the flat PEM in a Tesla Roadster on top of the battery. In the Model S it is the cylinder that is next to the motor.I thought the fuel cell was that smart-looking flat laptop-sized thing on the top, and even then I thought it was "large" as I had assumed a fuel cell only needed to be the size of a match box from all the hype I'd heard about how amazing they are.
Here's a diagram of how the Mirai is laid out:
I think it is because when they put it in all the trunk it takes up too much cargo space (this design still has the drive battery take up space though). Also they can't put it too far in the rear because of risk of rear end collisions.I see.
So the high pressure hydrogen tanks are under where kids will sit.
Ok...
Thanks all, very informative
Wow! None of the benefits of simplicity of the BEV and therefore loss the potential of BEV's very high mileage (compared to ICE). You don't know until you know, of course , but I had assumed that FC was just a bolt-on box (and H2 tank) that would charge a battery in an otherwise "regular" BEV; I know better now, thanks.
Tangential question: I see H2 being dismissed here because of difficulties fuelling the vehicle (both fuelling the vehicle, and storing H2 at the service station too). Why is H2 harder to refuel than LPG? I have never driven LPG, but looking at a map there are plenty of conventional petrol stations around here that also have LPG available - many more than decent electric charging locations, let alone superchargers!
EDIT: (i.e. I had, naively, assumed that H2 distribution would be as easy to add to existing service stations as LPG clearly has been)
