So people that use ABRP use it on their phone screen while driving?
Sorry if this is a dumb question. I am new to this, still waiting for my ordered MY.
In general,
I mostly use ABRP at home on my computer while preparing my trip.
I would recommend playing with ABRP, because it is a little bit tricky to use it
and to understand the numerous settings provided to customise your itineray.
Then I make a printout summary or I make a screen copy of the itineray
and the additional detail information and send those images to my phone.
Something to consider when doing a long trip is to choose as preference fast V3 Superchargers (250 kW)
instead of the older V2 Sperchargers (150 kW) which share the same inverter, so you get only half of the power.
Also I check what amenities are available at the the Superchargers that will use,
and modify the ABRP predefined itineary to use the Superchargers that I prefer.
Note: Some amenities providing restrooms might be closed, depending the time or arrival,
to know in advance whereto find a rest area, which are open 24h.
One limitation of ABRP is that you cannot reverse the itinerary like Google does.
You need to save your itinerary and generate a new return itinerary.
So I use two accounts on two separate browsers, such as Google and Firefox.
This allow me going back and forth between my going up itinerary and my return itinerary.
During the trip, I solely use the Tesla Navigation, because the consumption is more accurate.
It is difficult to estimate the weather condition, in particular the wind strength and direction.
Also the trafic might affect your speed, in particular on a two lanes each side freeways,
when a big truck decides to pass another one and forece you yto slow down.
However I try using the Supercharging that I selected in advance using ABRP,
instead of the ones that the Tesla Navigation selected. I wish there was a setting
to indicate that you prefer using the V3 Superchargers when possible.
Note: I try to end each lap with about 25% to be sure that the car will precondition the battery,
because this feature will not work with a battery with less that 20% of charge.
In the case of Superchargers located inside a city, often inside a shopping center,
is to look at the itineray gernerated by the Tesla Navigation.
Because this itinerary is often not optimal and make detours.
You could find a better and more simple itinarary using Google or ABRP.
