nativewolf
@wdolson not sure if you saw this but I hope it will make you smile.
Denys says not the airport but nearby military base.Reports that Ukraine is hitting Russian occupied Mariupol, possibly the airport.
Ideally the Russians and the Wagnerites start a little internal fight and do it for us all.If Ukraine gets them before they get away, it will be a wonderful service to humanity.
Will Russian glide bombs delay or hamper the counter-offensive?
Prof. Michael Clarke recently said that glide bombs were playing havoc with Ukrainian front line forces and Ukraine now has a dire need for fighter aircraft. Shortly after that the US and other allies got on board with supplying fighter jets and pilot training to Ukraine. Kudos to Prof. Clarke for getting this right which makes the rest of what he said more believable to me.
@Ogre asked the key question: can Gepards shoot down glide bombs? I could not find a definitive answer to this. ISTM that if they can then Ukraine only needs Gepards near the things they want to protect; they don't need to protect the large number of square kilometers in range of a glide bomb plus its launch aircraft. Granted, there may be a gruesome choice between protecting civilians and protecting military assets.
The estimates I've seen say it will take 3 to 6 months to start building up the Ukrainian Air Force with the training and planes that have been recently promised. Maybe there are more optimistic projections. This makes me wonder if Ukraine will delay their counter-offensive until they get enough jets in the air to neutralize the glide bombs or if Ukraine can counter the glide bombs well enough now to go ahead with the counter-offensive before they build up their air power.
IIRC, Russia is launching about 20 glide bombs per day. Since they are cheap to make it seems possible that Russia could increase their production by a factor of 10. Or maybe the production rate is higher and they are stockpiling for the upcoming counter-offensive.
My hope is Ukraine can counter the glide bombs well enough with their current equipment so they don't need to delay the counter-offensive. Perhaps they were downplaying this capability to the West in order to make a stronger argument for getting fighter jets and training ASAP.
- Going back three or more decades these types of systems were tested using 4.5" shells as the target, and they worked. A 4.5" shell is a harder target than a bomb with a wing kit. My specific knowledge is of another similar system to the Gepard/Oerlikon one, but I see no reason why the Gepard/Oerlikon would not be equally effective. as the G/Oe is a very capable and comparable system. I do not think you will find any public domain evidence that is going to give you a better answer than that. The real issue is that the Gepards (and other similar things) are simply not available in large enough quantities to protect the large numbers of assets that are at risk. The Ukraine simply has to prioritise where these Gepards/etc are located, and sadly putting them 20km behind the front line in a muddy field next to some towed artillery is just not high up enough on the priority list. Playing goalkeeper on the real high value assets is the right place to put th eGepards at the moment. Clearly that prioritisation will change as the nature of the warfare shifts (hopefully) in the near future, but still it will be difficult for Ukraine to push more than a few of these things forwards.@Ogre asked the key question: can Gepards shoot down glide bombs? I could not find a definitive answer to this.
Sometimes I’m a bit too succinct when I post things and perhaps this was one of those cases.Going back three or more decades these types of systems were tested using 4.5" shells as the target, and they worked. A 4.5" shell is a harder target than a bomb with a wing kit. My specific knowledge is of another similar system to the Gepard/Oerlikon one, but I see no reason why the Gepard/Oerlikon would not be equally effective. as the G/Oe is a very capable and comparable system. I do not think you will find any public domain evidence that is going to give you a better answer than that. The real issue is that the Gepards (and other similar things) are simply not available in large enough quantities to protect the large numbers of assets that are at risk.
Relevant to our Tesla mission;
Ukraine found an unlikely tool to resist Russia: Solar panels — The Washington Post
Ukrainians are putting solar panels on hospitals, schools, police stations and other critical buildings to fight blackouts.apple.news
This was my fault. I skipped over your main point when I cited your question and I was too lazy to even provide a link back to your original post. Sorry about that.Sometimes I’m a bit too succinct when I post things and perhaps this was one of those cases.
Your last point is what I was referring to when I said the big problem is surface area.
As you suggest, there is simply too much ground and too many assets to protect. Particularly since Russia has no qualms about civilian targets. Likely that’s a part of why they target civilian infrastructure so often.
Ukrainians are doing such a good job at information warfare that nobody knows what they are doing. Russia is sending reinforcements away from the main front trying to reinforce Bakhmut, Ukrainians are taking advantage of that. Meanwhile Zelenskyy is telling people they don’t have enough resources to start the offensive, they are destroying so much infrastructure….Ukraine is doing multiple attacks on railways. It's either the Ukrainians doing a fake out or the offensive is about to start. Railways are fairly easy to repair. Taking out a rail line will put it out of operation for a few days at best. Taking out a lot of rail lines at once is something that an army preparing for a major offensive would do to paralyze the enemy in the critical first 48 hours of an offensive.
Ukrainian officials denied that Wagner had established complete control in Bakhmut, but called the situation in the city critical. Serhiy Cherevatyi, spokesman for Ukraine’s eastern command, told the Associated Press that Prigozhin’s claim “is not true.” Ukrainian “units are fighting in Bakhmut,” he added.
I gather it depends on the definition of what constitutes Bakhmut.Wagner claiming Bakhmut has been taken by them but Ukraine denies it.
Russia’s Wagner group claims control of Bakhmut, but Kyiv says fighting continues
Heavy fighting was continuing in the city, Ukrainian Deputy Defense Minister Hanna Maliar said.www.politico.eu
