The car will then automatically start charging at a time so the car reaches the desired SOC at the time you have set (actually about 15-minutes prior.)
Got me there. Here is Atlanta my car is ready 15-minutes prior to departure.Overall good advice! I would just add that when I use Schedule Departure it seems to reach the desired SOC about 45 minutes prior.
Maybe the early SOC is to leave time to condition the cabin and battery?
I have enabled scheduled charging set at 8:00 p.m.You can select schedule charge or schedule departure, but not both.
If you set a Schedule Charge the car will start charging at the set time. For example, it you set it to 10 pm and plug the car in at say 8 pm, the car will not start to charge until 10 pm, it will then continue to charge until the car reaches the SOC you have set.
Schedule Departure has two settings, each with its own time. Off-peak charging (misleading name) tells the car what time you want it to finish charging. For example, if you set it to 5 AM and plug in the car at 8 PM, the car checks the available charge rate (does a small charge to get this), and it looks at the current SOC and the desired SOC. The car will then automatically start charging at a time so the car reaches the desired SOC at the time you have set (actually about 15-minutes prior.) The other option is pre-conditiining. If you choose this the car battery and cabin will be warmed or cooled so you are ready to go at the chosen time! Note that selecting schedule departure by itself does nothing. You must also select off-peak or preconditioning, or both.
Same here, when precondition is enabled, I usually get a notification around 45 minutes before 08:45 amOverall good advice! I would just add that when I use Schedule Departure it seems to reach the desired SOC about 45 minutes prior.
You will need to give a whole lot more detail than that. Picture of Charging screen, charging setup, etc.
is using the off-peak function the only way to get it to stop charging without intervention? would be nice if we could just choose a time to stop charging, in the same manner as we can to start charging.
You can use a 3rd party app like this Charge your EV for less
The Sheduled Departure is a stop charging feature. Just set the departure time then the off-peak end time at or after the departure time.is using the off-peak function the only way to get it to stop charging without intervention? would be nice if we could just choose a time to stop charging, in the same manner as we can to start charging.
Yes!! Car settings override app settings. You have to go to car to plug in. Just set up Scheduled Departure from charging screen. Then plug in and your car will be ready about 30 minutes prior to departure time.… I should say I’ve been attempting this from the mobile app, maybe it’s different from inside the car
I think people are over complicating things by wanting to do everything from the app.
I set mine to start charging at 12:30 am for the lower price of electricity, I see it on the screen "charging will start at 12:30 am. but for some reason, it starts charging before the time it should. I do think it has been down to updating the software, sometimes. Anybody any bright ideas?You can select schedule charge or schedule departure, but not both.
It starts charging to calculate estimated charging time. Once it knows this it stops and schedules the starting time to complete about 30 minutes before your departure time.I set mine to start charging at 12:30 am for the lower price of electricity, I see it on the screen "charging will start at 12:30 am. but for some reason, it starts charging before the time it should. I do think it has been down to updating the software, sometimes. Anybody any bright ideas?
At what time do you plug in the car?I set mine to start charging at 12:30 am for the lower price of electricity, I see it on the screen "charging will start at 12:30 am. but for some reason, it starts charging before the time it should. I do think it has been down to updating the software, sometimes. Anybody any bright ideas?
