Science Park Super Charger failed to charge our battery
Discussion in 'Hong Kong' started by angelitali, Oct 19, 2016.
Tags:
  1. angelitali
    angelitali New Member
    Hong Kong
    We took the Model S for a charge yesterday, saw a couple of cars leaving the port right after trying to charge without knowing what's wrong and went ahead to charge when it's our turn. After inserting the charger, message DC charger failed popped up. It apparently blew the battery instantly, our car is in the shop now.
  2. ediot
    ediot Member
    HONG KONG
    holy turd... did you have to call for towing? or did you contact tesla services in HK?
  3. ifung90
    ifung90 Member
    hong kong
    Wow i plugged it in there too .. it said check charger battery so i unplugged right away
  4. smtung
    smtung Member
    Yuen Long
    why didn't they disable the charger?
  5. frangus6
    frangus6 Member
    Hong Kong
    Are we talking about all the chargers in science park or just a particular one with problem?
  6. ecarfan
    ecarfan Well-Known Member
    San Mateo, CA
    This is very disturbing to read. Please explain what you mean by "blew our battery instantly". Does that mean that after you saw the message displayed in the car, the car would not move when you put it into Drive? Did your car have to be towed to Tesla Service?
  7. Lerxt
    Lerxt Active Member
    Hong Kong/Australia
    Blew our battery means nothing. A component failed in your car while supercharging.
  8. Chopr147
    Chopr147 Active Member
    Wantagh, NY
    I recently had the on board charger replaced. My S would not take a supercharge. Regular 220v charging still worked fine.
  9. ecarfan
    San Mateo, CA
    Agreed. The OP has yet to clarify what happened. Apparently during Supercharging something failed in the car. It is impossible for an owner to determine what failed or why, only that the car is "broken". So to say "Supercharger blew our battery" is misleading and inaccurate. The thread title should be changed.
  10. Electroman
    Electroman Well-Known Member
    TX
    OP: Thanks for taking the time to alert and share for the benefit of others.
    Giving piece meal information only opens up more questions.
    - what do you mean by, 'blew up'? There was an explosion, fire and smoke like we see in movies?
    - if not were able to drive back home or to an SC? Or did you have to tow it?
    - did you get a chance to plug into a 250V socket and did it charge?
    - will you come back here and give an update ?
  11. Doug_G
    Doug_G Lead Moderator
    Ottawa, Canada
    Changed the thread title to be less sensational.
  12. ediot
    ediot Member
    HONG KONG
    hopefully it is just some minor component that's easier to replace. it's scary to read since the supercharger bypasses the on-board charger, and charges the car battery directly (DC -> DC)
  13. Chopr147
    Wantagh, NY
    This is what I mentioned to the SC because I was a little confused. He was not sure himself other than to say the "bypass" is part of the On-board. o_O
    My take of it would be the bypass is hardwired inside the On board. A relay? Inside the on-board? If so and this becomes an issue, it is a more expensive fix than it needs to be.
