If you don't mind, please explain to me how you're able to figure out what price an option will be at a certain SP as demonstrated above. Thank you!I plan to buy Jun '26 250 calls when they are down to around $20 ($135 SP)
Technically, my “target” is $155, that was my target ~ 2.5 months ago (for this moment) and a bit more has changed, but I’ll stick with it overall. but my start to accumulate begins ~ 166 and then builds as we go lower approaching 160.Bear are in control premarket. Pain may be here longer then usual.
Recap - dl003 target 143 wave C, Tivoboy 165/160, Yoona waiting to buy at 160………..
yes, I use this Barchart options price calculatorIf you don't mind, please explain to me how you're able to figure out what price an option will be at a certain SP as demonstrated above. Thank you!
if you buy +p, dealers will sell stock to remain delta-neutral; this forces the underlying to fall (ie continuous cycle) - this doesn't mean they have profits, they are just offsetting their riskCan someone pls explain the following:
We hear:
"Large amounts of puts are flowing in, SP will drop."
Then we hear:
"There are so many puts/large -GEX wall at 'x' strike, there's no way MM will let price go down there to pay out the puts.
How to reconcile the two?
TradyTics updated options dashboard:
Closing these at B/E.It's not an ordinary put spread.
+2 185P paired with -3 180P. The breakeven point is 168.2. Above 168.2 by 3/22 it'll be in profit.
According to my current wave count. It should reach 180 at the minimum, likely 185, then big risk of turning down again.View attachment 1025304
Well darn, thanks a lot! Without this piece of info how could I have known sentiment was bearish yesterday. /s
TSLA is resting on a few good supports here.
On the lower timeframe, it's reached the 4.618x extension of the 1st wave from 206 to 194 around 172. This is strong
On the higher timeframe, it's reached the .381x projection of the 1st leg down from 265 to 175. This is weak as historically it can go to the 0.618 projection at 150.
Also the lower band of AVWAP. This is semi strong because we've tested once last month. Retesting so soon means it loses some of the luster.
Oof..QTA levels for today
3/8
3/15
1.8By break even?
Done, closed @b/e (1.40 for me)Closing these at B/E.
180.10 seems. Been super fun watching PA this morningAccording to my current wave count. It should reach 180 at the minimum, likely 185, then big risk of turning down again.
I've been following this trade, the current ask is closer to 2.50, the bid is 2.00 , how do you close these at 1.4 and 1.8 ? Trying to get a good feel for this trade, makes sense, just unclear how the closing could be had with the ask/bid spread being what it was.Done, closed @b/e (1.40 for me)
