N5329K
You might want to take a brief tour of the Model S "Technical and Mechanical Issues" thread (the S is a "mature" design by Tesla reckoning), and then decide about the service requirements of (very complex) electric cars.Electric cars still have a cooling system, but its simpler as it only has to cool an electric motor and a battery, not something that literally has explosions going on inside it.
Electric cars primarily use regenerative braking, and the friction brakes are there more for emergency braking than anything else. I drove my 2001 Honda Insight over 152,000km and not only didn't need to change the brake pads over the entire time I owned that car - I couldn't even detect any wear happening to them. I bought the car at 150,000km on the odometer. It had the same brakes on it when it was destroyed in a rollover collision ~152,000km later. I don't know for sure, but I suspect those pads were the original pads the car was delivered with. That was with a hybrid electric motor only good for about 10kW of regen, compared to the what, 100-200kW of regen that full BEVs are capable of? You will most likely need to change the brakes on a Tesla because the rotors are rusting away before you'd need to change them because of wear, and even that usually only happens to cars when they're not driven often enough.
There will of course still be wheel bearings and tires, and suspension components that need service, but the things that a BEV eliminates or significantly reduces from the maintenance equation are the high-frequency ones. The low-frequency service needs are pretty much unavoidable in a mechanical system.
Robin
