MitchJi
Trying to learn kindness, patience & forgiveness
Yes, but soon they will be able to increase the pack size, and reduce costs and increase margins.I toured 49 states last summer in an S 70D with 240 miles range. It is plenty of range for the base model. There's no need to raise the size of the base model S battery and thereby raise cost as well.
Saying that their is no need is like saying that they didn't need ludicrous mode, true but they did it anyway.
I'm betting you that the M3 pack size is closer to 70kWh than 47kWh that you mentioned. I'll send you some gourmet chocolate/raw cacao if you're correct. I'm not expecting anything in return if you're correct.
IMO M3 pack size over 60kWh is a slam dunk.
Not unless EM and JB have been lying.It's also possible that Tesla and Panasonic move to prismatic cells. Prismatics are space efficient, but have bunch of disadvantages in price, performance, how to warm them and reliability under physical stress. Having said that, if most issues are solved, I don't see anything wrong going in that direction. Tesla is not about religion, it's about pushing bondaries and staying 3 steps ahead of competition.
Larger Cell Format:
I have wondered why I have seen statements that the new larger cell format would lead to 30% increased pack energy density. It will not. I think that the source of the confusion is the following statement by EM:
Elon Musk - Chairman and CEO said:Right. We've done a lot of modeling trying to figure out what's the optimal cell size. And it's really not much -- it's not a lot different from where we are right now, but we're sort of in the roughly 10% more diameter, maybe 10% more height. But then the cubic function effectively ends up being, just from a geometry standpoint, probably a third more energy for the cell, if you -- maybe 30%-ish. And then the actual energy density per unit mass increases,...
To simplify the calculation in the following example I used an increase of 100%. But with a 30% increase the results would be similar. A circle with twice the diameter has four times the volume. But if the cells have twice the diameter only one fourth the number of cells will fit in a given space, e.g.:
A 100mm x 100mm space will accommodate 100 cells with a diameter of 10mm (10 x 10), but only 25 20mm diameter cells (5 x 5). So it roughly evens out, four times the capacity per cell, but in a space with the same dimensions only one fourth the number of cells will fit.
The reason they are changing the cell size is to reduce the cost, probably largely due to decreased pack complexity:
JB Straubel - Chief Technology Officer said:Yeah. Yeah, fundamentally the chemistry of what's inside is what really defines the cost position now. It's often debated what shape and size, but at this point we're developing basically what we feel is the optimum shape and size for the best cost efficiency for an automotive cell.
