Only time I used range mode was when my daytime running lights were partially burned out and they looked ridiculous. Range mode keeps those off
Range mode is beneficial if you are planning to use the climate, as it will limit power. It will also heat the batt for greater efficiency which can be detrimental on short trips.
When using range mode, SMT shows a slight drop in RM, 2-5 miles.
Tip...avoid using split setting on the AC...it will actually turn on the PTC on the warmer side!
Pretty sure I have seen the heater come on per SMT, and at above ambient temps.I’m pretty sure that while it sets a higher passive battery temperature target while in range mode, it doesn’t actually use the battery heater to achieve that higher temperature. It just allows the battery pack to scavenge more waste heat from the powertrain.
The battery heater won’t come into play until you either start charging or set a Supercharger as a destination, and in both cases, only if the battery temperature is too low.
There are other factors which you might not be considering such as head winds and traffic. Very hard to come to a conclusion with two data points.For the first 2 years i had the car i only drove with range mode on. Then i randomly decided to turn it off and i actually got better range with it off. I only made a note of 2 trips because i tend to forget most trips. i drove from carson city to mammoth on 2 separate trips about a month apart. first trip range mode on with temps of 40f outside no cabin heat only seat warmers start at 94% arrive at 21%. Second trip same exact route and no traffic either trip. range mode off this time outside temp is colder at 30f start at 84% arrive at 19%, no cabin heat only seat warmers. both trips had same tires at same pressure and same speeds.
As you can see i used 73% with range mode on, and only 65% with range mode off. and it was colder outside which means the battery heater was likely doing more work the second trip.
Clearly this is only one example from one driver, but i tried to eliminate as many variables as were in my control and i did better with range mode off.
I haven't turned it on since and i dono but i get plenty of range and the car works great. 2014 P85D 119k miles
Yes there could be other factors at play. traffic is a non-issue as there never is any on 395. Winds, possible yes. However, i only posted 2 examples as that's what i have written down in my phone. I had a spreadsheet with multiple data points that all confirm the same result, but i cant find where i saved it on my computer, (that's what happens when you have over a dozen hard drives on a single computer).There are other factors which you might not be considering such as head winds and traffic. Very hard to come to a conclusion with two data points.
It's there after rebootRange mode is gone now. Nowhere found in my X after 2022.4.3
Ive free juice. I just want to skip a day before charging if I can.I keep mine on range mode all the time. I don't see a benefit to not using it unless I have free charging, which I don't. Juice is expensive for me so I'm always tryi to be efficient
