I recently had solar and two power walls installed by a third party installer. The house has two panels so each power wall is on its own panel with its own gateway. I have a Model 3 that I charge via the mobile connector on a NEMA 14-50 outlet.
Since the installation when I charge my Model 3 it charges at normal speed at first (~34 mph) drawing from both the power wall and/or solar/grid as necessary. This all seems to be working appropriately. However after an hour or so of charging the rate of charge halves to 17 mph and stays that way for the rest of the charge. Sometimes it stops drawing from the grid and sometimes the PW runs out and it’s only using the grid, but either way the rate of charge is reduced to 17 mph.
Any suggestions on what the issue may be?
