Smart suspension question(s)
Discussion in 'Model S: Driving Dynamics' started by TrevTremaine, Jun 3, 2016.
  1. TrevTremaine
    TrevTremaine Member
    Toronto, Ontario, Canada
    I've just been playing with the car since it's brand new - first full day of owning it. My question is about the smart suspension - I've tried to raise it a couple of times and it always seems to return to the standard height within a few seconds. Looking at the manual, it says that you need to hold the brake pedal down (and I've done that) - same effect.
    Have I missed something here or am I using it wrong? I was trying to use it to raise it to avoid a curb. No speed as I was on the brakes. I also thought that one could potentially need to adjust ride height on the fly so something doesn't makes sense.
  2. Geoff
    Geoff Member
    Seattle, WA
    This seems strange to me. I am currently parked at work and I have my car as high as possible to avoid the curb.
    The only reason my car lowers to the standard height is when I am driving above 35 mph. I'm sure you have rebooted the car and all of the other "typical" things we do when something doesn't work properly. If it still is a problem, I'd talk with the Service Center about it...
    Good luck!
  3. Boourns
    Boourns Active Member
    Dallas
    Yeah something is not right from your description. If you are below the necessary speeds (something like 35 for high and 22 for very high) you should be able to adjust on the fly, even if the car is moving.
    Do you see a message in the top middle of the screen saying that the car is in an auto-raising location? If so, X that out to start from a clean slate. Just taking shots in the dark, but maybe if you have been playing with it a lot in one spot there are conflicting messages?
  4. TrevTremaine
    TrevTremaine Member
    That's a possibility. I will try both clearing the auto-raising location as well as a reboot.
    No error messages are popping up either.
  5. TrevTremaine
    TrevTremaine Member
    Dumb question: can someone tell me exactly how to do the reboot? Is it just a matter of going through "E-Brake and Shutoff" to do the shutdown? How do you restart - does it happen automatically, is it prompted or what?
  6. Boourns
    Dallas
    Push and hold both scroll wheels on the steering wheel. That'll restart the 17 inch screen. Do the same with the top steering wheel buttons and that will reboot the driver display.
  7. TrevTremaine
    TrevTremaine Member
    So, it turns out the latest software update fixed it. All is well now. I had booked an appointment, but cancelled it after making sure the update was working for a few days.
  8. SD Diver
    SD Diver Member
    San Diego
    Hmm... Same issue on my P85+. Set to go to the low setting at 55+ mph. Display shows that I am at standard. Press low, and 3-4 seconds later button goes back to standard. Frustrating. Which software update? I do not see that an update is waiting...
  9. Boourns
    Dallas
    ^ Dumb question but are you actually going 55+ when you press it?
  10. TrevTremaine
    TrevTremaine Member
    There was a software update I received notification while away last week. I did it on Sunday night and it resolved the suspension issue (so far as raising it). I'll give it a try with lowering at highway speed later. I don't know if it impacted all S models, or just the new facelifted ones. Mine is one of the facelifted models.
  11. DoubleE
    DoubleE Member
    Rancho Mission Viejo, CA
    Does anyone know if it's safe to reset the screens while driving?
    Never tried, and most likely won't. Would pull over first if needed.
    Just curious.
  12. Dithermaster
    Dithermaster Member
    Madison, WI
    Yes, the car is drivable during the reset, you just won't see anything on the screen(s). You'll lose sound (including turn signals, stereo, etc.) and HVAC but it all comes back within a minute.
  13. Chickenlittle
    Chickenlittle Active Member
    Virginia
    Done it and does not affect performance
  14. SD Diver
    SD Diver Member
    San Diego
    Yes - I'm usually around 70 mph when I press it. Low turns blue for a few seconds, then it goes back to standard. Tried the reboot last night in my garage - where the car is set to automatically go to very high. Sit in the garage, foot on the brake, I was unable to have it change to anything - would keep going back to very high. Disabled the gps aware part, but still no luck. I must be doing something wrong - or the owner's manual is wrong...
  15. Boourns
    Dallas
    I think you are doing everything right. Mine works according to the manual and it doesn't seem like you are doing anything different than I am. I might contact the service center to see if they have any tips.
  16. SD Diver
    SD Diver Member
    San Diego
    Thanks - I'll add it to my list for my 7/7 appointment...
