How the… I got 23 panels in East Bay and I only get 13 MWh.
This is by far the saddest chart of the day
ent
I have no idea why you wouldn’t at least be close to my numbers with your configuration…
Are all your panels south facing? I know that many of my friends have panel arrays on differ sections of their roofs with only most of them south facing.
I have vaulted ceilings which translate to a low pitch roof which in turn sets my panels at a very perpendicular angle to the sun for a larger portion of the year. I never realized before how much it helps to have the panels directly facing the sun (azimuth as well as elevation facing)
I’m inland Eastbay (Dublin) and its typical that people in the Eastbay, closer to SF will be in overcast while I’m in bright sunshine even though we’re both “Eastbay” It’s also typical that during overcast, the layer is much thicker the closer you get to SF and the coast. I have a friend with the same system as me but much closer to SF on the other side of the hills and he’ll be producing 2-3kw, at the same time I’m producing 5-6 when we’re both under solid overcast.
Do you have any shade at all cast on your panels during the day/season? I have clear view of the sun’s track, winter to summer for the entire day. Below is a typical clear day in early spring. Later in May-July production numbers will be closer to almost 70kw/day. You can see my 7.6Kw inverter clipping my production
, but my excess solar panels help me more in the winter than if I sized to avoid spring/summer clipping. This is also my production this month even though its been cloudier in this April compared to last.
In the end, there seems to be an infinite number of mysterious and not so mysterious reasons why two systems of the same config will vary in their numbers.
Are your numbers inflated to the same degree as mine were from Tesla? They told me based on my config, I would average 14.5 Kwh/year and I did 18. Was your delta about the sane given what they predicted for you?
