ACarneiro
Yeah, December sucks.
119 kwh vs a peak of 1.4MWh in May (I think it was a sunnier May than usual this year, to be fair)
I'm pleased that I didn't over-buy more battery than I really needed for the darkest month.
64.9 kWh generated in Dec from 6.48 kWp. 637kWh in August, wasn't installed in July.
96% of electricity bought offpeak, I'm pleased that I didn't over-buy more battery than I really needed for the darkest month.
What made the difference for us, was Octopus extending cheap rate for 6 hours, instead of the previous 4 hours.
I think even limited solar helps extend in those cases in winter too
We use more or less the same, 10.64kWh with a 90% DoD. Also the same as @PITA the extra hours of cheap rate make the most difference. Good days for solar in December tend to be a bit of a waste as we just end up with excess when the next charge cycle begins so it earns us 7.5p savings. While I try to pick my days for washing based on the forecast generation, Mrs Grilla uses more of a 'its all dirty right now' approach.I’m surprised we have mostly been ok with a 9.5 even when my wife puts on a double tumble dry session and we’re cooking (we moved to induction). I think even limited solar helps extend in those cases in winter too, to slow your discharge (plus that 9.5kwh is only covering 18 hours)
fairly well insulated
in deep Summer... the air conditioning is on all night (using cheap rate) in all bedrooms which is lovely, ultra quiet and a good night's sleep
Are you well enough insulated that you cuold AirCon-cool the bedrooms during the day (i.e. from PV) and not run it (or run it "less") on Off Peak overnight?
Unless your bedroom(s) are West facing ...
I'm in the middle of installing a Mechanical Ventilation and Heat Recovery system this year... for filtered fresh air into the house. It'll remove pollen and contamination from outside air, and extract bad air from wet rooms. At this point... it'll be optional to ever open the windows again.
I have MVHR and we rarely open a window - that just lets in the flies (and bats / birds!), pollen and heat (summer) / cold (winter). Add to that the constant middle-range relative humidity - hanging washing dries faster, no moulds in winter (nor condensation inside windows), no winter coughs / colds, great for folk with respiratory ailments like Asthma. But the diameter of pipes for a retro fit is a challenge ... blinking builders putting up New Builds should be putting MVHR in as standard ... and PV on the roof, and an EV charger ... I whinge more and more like my Dad did when he was my age!
Be interested to hear what you think, once your installation is all doneBest retro-fit we did to the old part of the house.
