CHG-ON
Still in love after all these miles
Great concept. There certainly is no shortage of paved surfaces on this planet. Good luck with the execution and maintenance.
Disagree. For example, my CA house has tile roof upon which you cannot economically mount panels. I could clear some landscaping and put in ground mounted array. But the landscaping is beautiful and mature. It's even better if I could pave my driveway.The basic question here is: when do you put solar panels on the actual ground [surface]?
The answer is: when you're out of building roofs and other elevated structured surfaces to put them on.
I don't think tile roof are much of a problem for solar installers. All the roof in my neighborhood are tile, and many have solar. Roof tops are not all that hard to work on for experience installers.Disagree. For example, my CA house has tile roof upon which you cannot economically mount panels. I could clear some landscaping and put in ground mounted array. But the landscaping is beautiful and mature. It's even better if I could pave my driveway.
Not handmade Mexican tile. My driveway is great for solar.I don't think tile roof are much of a problem for solar installers. All the roof in my neighborhood are tile, and many have solar. Roof tops are not all that hard to work on for experience installers.
Most driveways are not at a good tilt for solar and many have shade for a good part of the day, making them much less efficient compared to a roof mount.
I suppose putting solar panels on the ground might make sense in some places. But I also think it kind of moot: when the technology has progressed to a point where we can cheaply and easily "pave" panels to the ground I suppose we will also have stuff like solar panels that can be sprayed or painted on to - you guessed it - roofs
Tennis courts would seem to be a perfect spot for solar.OTOH there's a full size tennis court and a large drive. If they were covered with PV panels the output would be enough to make the house net zero. It's an odd case but the world is a collection of odd cases. If solar panels could cover pavement it would let Elon Musk's house go solar. Rooftop won't. In that case it solves a problem. Are there other Cali mansions like it? Thousands.
In large areas of the US, there's more area devoted to unoccupied pavement than rooftops. More importantly, if it worked, this sort of thin solar panel overlay would be a lot simpler and easier to install than rooftop panels and might have lower total costs.
I've read that in India, they are installing solar panels over irrigation canals. They already have the rights to the land. They also reduce evaporation from the canal.same as with the other one - this really seems to be a case of solving a problem that doesn't exist... it's not like we've run out of places to put solar panels that DON'T get driven on...
Depends how it looks and feels. Tennis courts are engineered for traction and bounce, and they are colored for ball contrast consistency and low glare. If solar messed those up then courts no longer good for tennis.Tennis courts would seem to be a perfect spot for solar.
1. They need to be kept clean
2. They need a stable smooth surface
3. They are not covered by parked cars, etc
