Yesterday we had another outage (3rd in the last two days) but before the last full outage my solar stopped producing and filling the Powerwalls.
I have a fairly new SolarEdge HD inverter with no display but it has three lights that were blinking. So I tried to restart it but same result. I was able to connect to the inverting using the SolarEdge SetApp from the Android app store in view only mode and found an 18x22 error.
I didn't find much online around this error so called Tesla support but they were not sure and decided someone needed to come onsite to look at it.
It then started working again an hour later but then turned back off. At the same time my neighbors started commenting on low voltage in our area. Sure enough I saw 106-107 volts and that was causing the inverter to shutdown.
Now that the power is back on today and working well the solar and inverter are working fine again. So figured I would post for the benefit of someone else in the future in case they run into this.
