You're making it sound like you have 360 degree coverage.
How would the dash cam see someone entering from the side? Would it see anything inside?
I understand it's great for front and rear accidents, don't understand how it would help here.
Keep your fob in a tuna can (covered with a larger tin can top) which decreases the fob's working radius.
It could be multiple personality disorder
I use Altoids cans, especially when camping or at a hotel. It already has a lid and my FOB doesn't smell like the holding bay of a trawler. ☺
This is my favorite solution so far. It does require someone contacting Tesla with this to make sure they implement it. It is a pretty serious security concern. Someone could easily plant false criminal evidence in your car, intentionally or incidentally.This passive entry attack can be thwarted using Time of Flight measurements to detect distance between car and key fob.
This method is used by Apple to prevent Apple Watch unlocking on Macs from falling prey to signal repeater attacks. I'm disappointed if Tesla hasn't figured this out
I see now that someone posted claiming Tesla permanently made the Model S's key unfixably insecure. Can't they sell new key fobs for Model S and use its bluetooth for secure entry rather than the current FOBs?
Akikiki said:
Yes, friend. But you are correct. Yes, its been modified from the old way that I described.
The first part I will call it is still accurate. Double click the fob, unlocks and don't open a door. Walk away. In about 1 minute, the handles will recede. With the fob out of range, walk back up and press a handle. The handles present as its unlocked. (You now have 15 seconds or less.) The second part. Whether you touch a handle to present or do not touch, now, 15 seconds later (if the door is not opened, the handles close and the car locks (It didn't used to do that). I am glad to see that they made this change.
Sounds like a homeless person found your car unlocked and shacked up. They weren't out to steal, just looking for a safe, quiet, comfortable (relatively) place to crash (and eat some snacks). Consider it a learning experience and a public service rolled into one.
Just one quick note on this... The frunk is the not necessarily a secure solution. On all Model X and on Model S in the past 3 years, you can access the frunk by simply opening an access panel on the front of the car and pulling a couple release cables. The Model X is the easiest to do this to. The Model S Refresh is the most difficult. The Model S mid-2014 up to the Refresh is also easy, but a little more conspicuous...... 1) don't put things in the trunk if it can avoid it; 2) secure stuff it in the frunk; 3) don't put stuff in the trunk or frunk and walk away. Secure the stuff before you get to where you are leaving the car; 4) If nothing is in the trunk, - leave at least one seat folded down so it looks empty and can be seen. It may save getting a broken window. .....
What @Musterion and I were saying, and reverified, is that the car no longer operates like that. If you double click the top of the fob to unlock the vehicle, it will retract the handles in approximately one minute, and then lock the car in approximately 15 seconds after that.A question for those discussing the "double click the fob but don't open a door" thing -- often times I'll double click the fob when I need to access something in the trunk, without interacting with any doors/handles otherwise. Does the vehicle treat the trunk the same as entry by a door? If not, then it seems like my double clicking to get in the trunk could allow someone access by touching the door handle later on.
(And yes, I know I could just push the trunk button on the fob, but sometimes we do silly things just because they happen to work.)
I'll be testing that theory later tonight unless someone knows for sure already.
