Space X Option Package
Discussion in 'Roadster 2022' started by McManX, Jun 9, 2018.
  1. Matias
    Matias Active Member
    Finland
    What about heating the expanding air with resistive heating?
  2. WarpedOne
    WarpedOne Supreme Premier
    Slovenia, Europe
    It is not worth it beyond removing/preventing the ice buildup blocking the thrusters.
    Stop looking at thrusters as naive rocket-like operation, directly pushing the car forward.
    Much more can be gained if these thrusters provide more grip of tires that already have COG higher than 1.
    This COG being > 1 means that each pound of thrust pushing the tire at the tarmac result in more than one pound of force the tire "pushes" at the car.
    While accelerating one fires the thrusters in the front of the car facing the sky. This provides additional down-force in-front resulting in much higher down-force on the rear axis. Double digit multiplication factor.
    Same thing during cornering - one fires the thrusters on the inside facing sky and thus provides for much (multiples) more grip.
    And same during braking - one fires the rear thrusters facing up to again provide much more grip on the front tires.
    As long as tires have COG above 1 the best direction of firing thrusters is up and as far away from car-tilting-axes as possible.
    When tire COG drops below 1 (dirty tarmac, gravel, etc) the best option is to fire thrusters in direction of desired acceleration.
    Now, when would one want the car to fly? Not sure abut this. What goes up must come down. How to do this while not making things worse I am not able to see.
  3. nowtleft
    nowtleft Member
    Uk
    I wish he would sort my Model S sat nav out - I am fed up of it telling me to pull into a layby and out 300 yards later - should be simple for a man who can make cars like this but he seems unable to crack it. I saw a thing on youtube with a ladybird following a line drawn on a toilet bowl - perhaps he should ask the Ladybirds for help with this seemingly HUGE problem? MORE focus LESS dreaming please Elon!!
    • Disagree x 2
  4. kbM3
    kbM3 Active Member
    Orlando
    Wow. I’ve rarely been gotten that good:)
  5. slipnslider
    slipnslider Member
    los angeles, ca
    Elon Musk on Twitter
    Right from the horses mouth. This will be too loud to use in populated areas. So what's the point then?
  6. MP3Mike
    MP3Mike Well-Known Member
    Oregon
    For track use of course. Just like the 0-60 time is too fast for populated areas.
    • Informative x 2
    • Disagree x 1
  7. mongo
    mongo Well-Known Member
    Michigan
    Non populated areas
    Salt flats
    The track
    Emergency braking
    Just plain cool
    Actual quote "Not recommended for urban environments", same thing is true for semi compression brakes. (South Park biker episode?)
    Heck Ford just put a good neighbor mode on the Mustang due to its deliberately loud starting routine.
  8. slipnslider
    slipnslider Member
    los angeles, ca
    So when a company, whose stated goal is the widespread adoption of affordable EVs, is struggling to survive, is spending on improving supercar performance on a track (situation where the car will spend a fraction of a percentage of its time) the wisest way to spend money?
  9. slipnslider
    slipnslider Member
    los angeles, ca
    All situations which fail to make the case for why this is the right thing for tesla to be spending on right now.
    • Disagree x 1
  10. MP3Mike
    Oregon
    Who said they are spending money on it now. It is plane for 2+ years out.
    But spending money on expensive high profit cars is what is making them successful.
  11. Zoomit
    Zoomit Active Member
    SoCal
    What is COG and how is it greater than 1?
  12. Gen3
    Gen3 Member
    AB, Canada
    YES
  13. Gen3
    Gen3 Member
    AB, Canada
  14. Zoomit
    SoCal
    Thanks for trying but that doesn't help me understand what he's trying to convey, and yes I'm pretty comfortable with the physics behind vehicle dynamics.
  15. Gen3
    Gen3 Member
    AB, Canada
    I assume it is coefficient of grip, and that if it is greater than 1, more downforce is better if motor has excess power. Ie, if cog is 1.5, you could have 1.5 times the force of if thrust is down versus behind the car.
  16. TEG
    TEG Teslafanatic
    #116 TEG, Jun 14, 2018
    Sort of like what Gen3 said... I take it to mean that small rocket/jet nozzles would fire up and push down on the car so that the tires have more traction than normal (more than 1G downforce) so the motor can put more power through the wheels without having the tires break traction. In other words you could accelerate quicker without spinning the tires. 0-60 in 1.9 is really pushing the limits of adhesion / traction for street legal tires, so they are resorting to some "bend the rules of physics" trickery to get more traction to extract more acceleration performance.
    Normally tires are pushed into the ground by 1 force of gravity... So having something push down on the car would help to get more than 1G traction from the tires.
    Some race vehicles used fans to suck air from under the car to create a vacuum that pulls down to get the same effect.
    Lots of race cars have wings and such to generate more downforce at higher speeds. Some kind of fans or jets would have the benefit of adding traction off the line and at low speeds.
  17. kbM3
    kbM3 Active Member
    Orlando
    Too funny. I actually made exactly the same retort, but went back and deleted it after i saw yours.
  18. nowtleft
    nowtleft Member
    Uk
    You may well disagree but facts are facts! Having said that I had an update over night which I hope will solve the problems. Please disagree with things that are subjective NOT factual as it makes you look like idiots!
  19. dhanson865
    dhanson865 Active Member
    Knoxville, Tennessee
    You keep saying this.
    Gross margins for supercars are well above 30%, highly profitable
    Gross margins for the regular Model 3 are lower.
    Spending money on supercar performance for the track pays back quicker with less effort and subsidizes the Model 3 with shortrange battery and Model Y with short range battery that I want to buy. It's a win win situation and absolutely what Tesla should be doing.
    Just like every 85/90/100 Model S and 90/100 Model X paved the way for the long range Model 3 now, every 100 S/X and every 2020 roadster with or without gas thrusters will pave the way for cheaper Model 3 and cheaper Model Y in the future.
    • Disagree x 1
  20. Model S M.D.
    Model S M.D. Ludicrous Radiologist
    TX
    Not sure if this has been posted yet, but Everyday Astronaut has a good discussion about this new "rocket thruster" tech:
    He estimates (very rough) a 1.4 s 0-60 is achievable and that this could cost upwards of 100K+
