Note: This feature currently requires accessing the site using the built-in Safari browser.
Between planes also otherwise planes must always be over a ground station.100 Gbps laser optical links are very very impressive. It helps a ton that they are in a vacuum, but still, each satellite is moving at 25,000 km/hr or so. I do wonder if their intra satellite links are just from one satellite to the next one in the same plane (in which case, the satellites should be more or less stationary relative to each other), or whether that picture above is at all accurate and they can communicate with satellites that are moving relative to each other.
And is 8,000 the current number of active lasers, or the number they'll have at some build out point?
So many questions...
I do not understand the “pew pew!” reference in the Starlink tweet. Is that supposed to be the written equivalent of a sound effect?
And why did Elon put the word “lasers” in quotes? I thought they were actual lasers.
He's just being silly. Yes, pew, pew is the sound effect that some sci fi shows use for laser beams. And the quotes are making fun that while these are indeed lasers, they aren't military grade weapons.I do not understand the “pew pew!” reference in the Starlink tweet. Is that supposed to be the written equivalent of a sound effect?
As @Buckminster pointed out, the quotes were a reference to Doctor Evil from the Austin Powers movies. Here's the video of the bit. Notice that the meme uses a frame where Doctor Evil air quotes "ozone layer", not "laser". The phrase "frickin laser beams" comes from yet another scene. So the meme is a real mishmash.And the quotes are making fun that while these are indeed lasers, they aren't military grade weapons.
Obligatory silliness reference:He's just being silly. Yes, pew, pew is the sound effect that some sci fi shows use for laser beams. And the quotes are making fun that while these are indeed lasers, they aren't military grade weapons.
It's why I've typically disabled the AP on vendor premise equipment like cable-modems, FIOS gateways, etc... when I'm using my own
Strange... App shows offline?What about disabling the star link AP and then not being able to connect directly to the starlink?. I use my own router switch and APs and disabled the starlink AP and router function so as to avoid problems from competing routers and APs, but now the app won't connect directly to the starlink the way it would through its own WiFi AP.
I hesitate to even post this, but I’ll just say my two cents.
This article actually derides SpaceX for not meeting a revenue target that was set 8 years ago. I loathe this kind of press.
SpaceX Is 2 Years Behind Schedule, But It Could've Been Worse | The Motley Fool
After all, the space company was three years behind schedule last year.www.fool.com
It's like setting a cable modem/ AP to bridge where the modem itself still has settings.Trying to understand.... I don't have Starlink, so going off my professional network experience, and that of home stuff I've dealt with:
What does "connect to the starlink" mean? Starlink can refer to the company, the service, or the antenna (also called "Dishy"). The item providing connectivity to your devices is the Starlink Router. Do you mean unable to connect to/manage the Starlink router/AP? Connection to the Starlink service to get to the internet?
Disabled what portion of the Starlink router? As it needs to talk to the Sats, this portion of the Starlink device must be enabled (I assume it's referred to as a "router", although not necessarily accurate).. Or did you just disable the WiFi routing function?
Again I don't know what "connect directly to the starlink" means. See questions above.
OK, so you can put it in bridge mode cool. So the unit should still maintain an IP address on it's internal ethernet interface in order to connect to and manage it.It's like setting a cable modem/ AP to bridge where the modem itself still has settings.
There's Dishy and there is the router which is also the power injector for Dishy.
You can set the router to bridge/ pass-through mode with wifi access point off so it is ownly power to Dishy and no other active network functions (3rd party router connects via wired adapter).
Normally, this should result in the App still having control over Dishy stow, melt, obstruction info, and such.
Oh, @bhzmark, is the Dishy IP/port blocked on your Access Point since it's on the wan side? (realizing it must be there as gateway)...
You should be able to access Dishy via browser at 192.168.100.1 (default), may need (direct?) wired connection.
Dishy is the modemOK, so you can put it in bridge mode cool. So the unit should still maintain an IP address on it's internal ethernet interface in order to connect to and manage it.
Is that what you mean @bhzmark by not being able to connect to "the starlink"? You can't get at the modem management interface?
If so, and you CAN still access the internet, then @mongo 's question/suggestion is likely...
A traceroute to 192.168.100.1 might help determine the issue.
Ah, no local administrative web portal. That's different.Dishy is the modem
Router is power injecting Access Point
System can run without Router if you put DC power on the right pairs.
The app pulls data from both Dishy and Router, it's not served by the router itself (as far as I can tell).
100.1 Web interface gives only Dishy stuff (no networking options)
So what does "not being able to connect to the starlink" mean @bhzmark ?
