jsmay311
Idk how reliable the weight numbers floating around online are, but I’ve seen it posted that the Model 3 pack is 1060 lbs (480kg) and the Model Y pack is 1700 lbs (770kg). I find it surprising that there’s such a big difference since they have similar kWh capacities, so idk what to believe.The specific heat of the pack is in the range of 850 J/Kg*K. From Bjorn's videos, I think active pack heating is in the range of 6 kW. A - 80 kWh pack weights about 800 Kg
So you tell me: how many degrees C will the pack heat up per minute with directed pack heating ?
My arithmetic says 0.5 C/min if 6 kW of heat is directed to the pack. If cabin heating is splitting the heat, then the pack heats up 0.25 C/min
But your math is right, albeit simplified, if you use your assumed battery pack weight and specific heat. But, in addition to heat loss to the environment, you also need consider that the drive units and the coolant itself have to heat up before they can deliver heat to the battery, so that’s more thermal mass that will require additional energy not going to the battery.
Here’s one real-world example where my 2018 Model 3 LR-RWD used ~8% of its battery capacity over the course of 97 minutes while parked just to heat the battery before a scheduled departure. Unfortunately at that time I had no way to see actual battery temps (I relied on TeslaFi to see power and energy usage and SOC drop) so idk how many degrees the battery heated up. And a RWD sans heat pump would perform differently than an AWD with heat pump.
