stopcrazypp
The presentation you linked yourself clearly says there is a battery capacity test that applies! It is not my own personal insisting.You insist on some sort of actual verification of battery capacity as part of EPA testing it simply is not a stated requirement.
"On-Dyno Battery Capacity Test: Extrapolation based upon dyno test, not from standard battery test data
– 55 MPH steady-state speed, in 50min segments with 10 min rests.
– Accel and decel specifications defined"
Here's the problem: the EPA does not intake a usable battery capacity number (separate from test data). They may separately intake the brochure nameplate number (85kWh or 60kWh for example), but no where do they ever take in a usable battery capacity number. This number is taken from the dyno based capacity test mentioned above (note how they say "not from standard battery test data"). The test data will be passed to EPA as part of manufacturer filing.The two figures Tesla MUST prove are MPGe (based on AC recharging input) and range. I am not saying either figures Tesla have published are incorrect.
They can report range by doing UDDS + HWFET * by 0.7 (to approximate the new 5 cycle tests) measuring DC draw and using their own knowledge of total DC capacity. (In the same way an ICE manufacturer can with an MPG figure and knowing what size tank they put in the vehicle).
This is different from gasoline case where the brochure nameplate tank size is all they need to get the range. Also the gasoline car range is not a legally required number on a new car sticker:
However, the EPA range number is legally required for EVs:
I'm not saying the consumers will ever see this number anywhere (they won't), but that the measured usable DC Wh capacity number is reported to the EPA as part of the test data (or can easily be derived from DC wh/mi and range at that cycle). I know that they easily measure this number during the test because they necessarily have to set up a DC consumption probe on the car just to get the efficiency numbers. So if we are able to get the actual raw EPA test data, this will show up there.However after a bit more digging it would seem more likely the more recent proposal (2012) currently in J1634 is to take a fully charged car run four rounds of UDDS, two rounds of HWFET cycles (again with a approximation factor). Then just use a steady 55mph of "filler*" for the rest of the test and "official range" is simply when the car stops.
(* I can't help but think 200 miles of steady 55 mph does wonders for the reported range)
Note under either regime this doesn't tell us as consumers how much usable battery the car has, because we have no way of knowing the efficiency rates of the chargers / chemical losses during battery recharge.
(We are getting way OT here, this should be in the battery thread...)
In your example of using 55mph filler cycles until depletion, by the end of the test, the DC probe would have measured a total Wh consumed during test, which is where we can get the usable capacity. If Tesla disabled brick protection during test (as wk057 speculated originally) that capacity would not only be ~5% higher, but the range would also be ~5% more.
Thus if EPA were to do that test independently with a production car, that discrepancy would show up (and would be an issue EPA is obligated to address, given the range number shows up on the new car sticker).
I would be interested to read the source document for that 55mph filler procedure too if you have a link.
