summon - cooler than I thought..
Discussion in 'Model 3: User Interface' started by angelman, Jul 24, 2018.
  1. angelman
    angelman Member
    los angeles
    I am probably just being dumb but only yesterday did I realise that summon actually drives the car to you, if you move around then the car will follow you like an obedient dog! Probably common knowledge but fun. May also explain why the car gets a little stubborn when I am too close.
  2. RDoc
    RDoc S85D
    Boston North Shore
    Are you sure about that?
  3. 1.21GW
    1.21GW Member
    Michigan
    Great Scott!!
    • Funny x 2
  4. Trevor B
    Trevor B Active Member
  5. Matt L
    Matt L Active Member
    OK USA
    It’s for sure cooler than it looks on paper.
  6. angelman
    angelman Member
    los angeles
    I'll try and take a video when I next get a moment. I need to do more testing but I found that when I summoned it up my driveway, as I moved to left or right it would start turning to follow me. I was able to then get it to turn away from the wall it was headed too and turn into my garage. Maybe it was just luck.. I'll try again. It's pretty flaky in general and rather shy (it rarely works when I am trying to show it to friends). Maybe someone else can try to see if they can get it to follow them.
  7. gujudog
    gujudog Member
    Don't think it follows. It may have detected a wall where it may hit if it didn't move and moved. It's definitely finicky for me.. Sometimes it detects things in my garage and moves to avoid, sometimes it goes straight for it. I use it daily to bring it in and out of my garage.
  8. Matt L
    OK USA
    I think it steers away from obstacles.
  9. irishndude4
    irishndude4 Member
    Pearland, TX
    I have only used it before to "show off" until today when I actually used it for its stated purpose in a parking lot when the idiot on my left had parked way too close to me for my comfort so I summoned it out, and I got in and drove away. Passenger was impressed.
  10. gizmoboy
    gizmoboy Member
    Rancho Palos Verdes, CA
    I'm 80% "just showing off," 20% "this idiot parked too close to the driver's side" on Summon...
  11. Ludalicious
    Ludalicious Active Member
    Vancouver
    I'm usually standing outside my car for 20 minutes swearing like a MOFO before I can connect to it.
  12. crackers8199
    crackers8199 Active Member
    lake elsinore, ca
    this. i tried today for the first time (picked up my car monday) and gave up after 5-10 minutes of it sitting on "connecting to your vehicle" or whatever the message is...
  13. P=VI
    P=VI Member
    Columbus, Ohio
    I’ve had pretty good luck with “force-killing” the app when this happens. When I reopen the app, summon connects right up.
    • Informative x 2
  14. JoganJani
    JoganJani Member
    San Jose
    What I have noticed is that when SUMMONed, the car drives exactly in reverse sequence the way it was driven in the garage. Usually I drive straight in to the garage and immediately turn sharp left in to the wall and then straighten it out. When I summon, it exactly follows the same steering patters I made but in reverse order.
