Hypertrev11
I think these could be easily retrofit to accommodate towing/Cybertruck drive through…. Could be a squeeze though.
That's odd - a 20-stall 5-cabinet v3 Supercharger should be able to pull 1400 kW from the grid and average 70 kW per post. Only getting 53 kW makes it seem like something else was limiting power. 53 kW * 20 = 1060 kW - maybe the entire site is limited to about 1 MW? Even then, many people charge way higher than they need to so that should allow for more power than the average...As the SuC was completely full, my car was only dealt 53k at 20% SOC. I only took on 15% and left since it was slow. I'll be back in Brea in a few days to give it another spin.
I'm guessing that there was something wrong with either the stall or cabinet you were plugged into...
Yeah, I did the math wrong - it's 350 kVA per cabinet and there are 5 cabinets there, so it should be 1750 kVA for the site (not sure where you got 1935 from). Since the power factor is most likely 99%+, this means 1750 kW for the site, on or average, about 87.5 kW per stall maximum.I have been told that when sites go live Tesla typically limits the sites full power output until they complete some tests internally but that came from an unverified source. A theoretical peak though would be 1935 KVA on the AC side if loading up all of the stalls.
It could also be that we have had “fiex alters” in CA for the past several days due to high temperatures, fires and uncertainty with electricity availability from NV and OR for 9am-4pm daily. Even a station like this could be throttled from the grid at times.That's odd - a 20-stall 5-cabinet v3 Supercharger should be able to pull 1400 kW from the grid and average 70 kW per post. Only getting 53 kW makes it seem like something else was limiting power. 53 kW * 20 = 1060 kW - maybe the entire site is limited to about 1 MW? Even then, many people charge way higher than they need to so that should allow for more power than the average...
sounds more like some tesla owners are not very clever.A serious design flaw with this location (IMO): a lot of cars park on the wrong side of the posts (on the row in the middle).
For example, in this photo, the 3 on the far side is actually parked in the wrong spot on the far side: they should be parked in the open spot between the white 3 facing the camera and the grey X. This causes it to look like this is an open spot when in fact it is being used by the 3 facing away. As I’ve sat here, I have watched several people pull in, thinking a spot is open when in fact it is being used by someone incorrectly.
Just my $0.02
Clever? Not sure that applies. maybe not situationally aware.sounds more like some tesla owners are not very clever.
In N Out does this at pretty much all of their newer locations (can't remember when they started doing this). Don't recall ever seeing any collapse (though I am sure it is possible)I wonder if those two palm trees would not collapse in case of an earthquake?
