canasion35
If you’ve worked with coilovers before I’d say you can do it in about 1 hour (taking wheel off, fixing preload, putting it all back together). If you aren’t comfortable with it you can take it to a shop too.i believe i am having this exact same issue now. Whenever i am at slower speed like turning into my complex or turning left over a speed bump, i am hearing some binding like sounds from front driver side. doesn’t happen on the right side. This started happening about 1.5 months after getting tein flex z installed.
Is tightening the preload easy enough to do or would it be best to have the shop do this for me instead?
The first thing I’d try is to spin the steering wheel back and fourth (full lock to full lock) a bunch to maybe unbind that area and get the spring to spin freely again.
