FortNine blames the two fatal motorcycle accidents in just 17 days apart in July in 2 different states CA and UT on the removal of radar.
Radar might have problems with stationary obstacles, but it has been quite good with moving obstacles traveling in the same direction.
When the radar is removed, vision needs all the visual clues it can get. At night the visual clues are reduced: "empty highways so we have few linear perspective cues,"
It may confuse the motorcycle's rear lights for a car's and take that as a distance cue: The farther the lights apart mean you are near to the car in front, and the closer they are apart means you are still far from the car in front (except it's not a car, it's a motorcycle in these 2 cases.) It might not classify the object in front as a motorcycle if it didn't see the rider above those 2 glowing red lights in the dark.
He also shows that Unadjusted for the highway advantage, there are fewer crashes with Autopilot:
However, when Adjusted for the highway advantage, there are times (Q2 2019, Q4 29019) that there are more crashes with Autopilot:
His solution is to add LIDAR.
