I am finding it hard envisioning a construction site more horrifying than one where a number of PV panels were so strewn about. Please trust Cattledog and others that they really, truly are not solar panels!
You are absolutely correct. Being the business, it's also called Q-DeckIt's galvanized metal deck that spans between the beams. What looks like a solid roof structure is simply the beams marching off in perspective.
Above metal deck there may be a slab, but I doubt it on the roof. Would have insulation, then a membrane roof, then we'll see a zillion solar panels interspersed with rooftop mechanical equipment.
"Module" dimensions appear to be 500' x 320' based on what they currently have foundations for. That's 160,000 sqft per level, and then it just depends on how many modules they go with. I agree that it does not look like they will be able to fit anywhere near 10,000,000 sqft in the currently prepared area.
I probably should have included the Gigafactory picture in my post for reference:
Hmm ... you mean something like this?I'm wondering if the 4 white lines we see cutting across the Gigafactory which break it up into 5 separate sections actually represent different buildings that are co-joined. In other words, will we see one or two of those 5 sections get finished on the exterior and they start putting in the interiors as the next section is built.
Yes, great drawing!
A number of bears have pointed out that Tesla might not have all the money to build all of the Gigafactory yet. However, nameplate capacity is not expected until 2020 and first cells are expected now in 2016. So do they build the whole exterior, or really do we see a part of the whole thing.
I think you mis-labeled the distances on your black lines, supposed to be other way around? Just from eyeballing the dirt truck in bottom right corner that is at least 30ft long, parked parallel to the 271 foot line, could easily line up 10 of those and not get very far down the line. Thanks!Okay, after some Googling and a little scaling, here's what I get;
The yellow cranes in the picture appear to be Liebherr LR1300's (These guys also seem to have a few, Bragg Companies - Branches) and the largest lower lattice boom sections comes in 40' 2" sections, which they appear to have installed on these machines.
I scaled the image using the lower boom section as a reference, and you can see (hopefully) the rest of the dimensions.
40' First floor clearance
25' Second floor clearance
The other interesting thing is the second floor joists are smaller depth W beams, and not open web joists like you'd see in a normal warehouse/factory application, so they are preparing for a ton of weight to go on top.
However, I think the perspective is still misleading as if you look at the bays on far left side, you'll notice that they are approximately half of the 50' ones, but are not square, which means that the gridline spacing is probably more like 15'.
I have only ever installed 2 metal roofs in my time, so take that for what you will) when you link the pieces together you almost have to start from one side working your way to the other. But you see random single pieces stuck to the roof all by themselves... and that seems like a very terrible way to build that. I know they aren't likely to get much rain out there... but when it does rain you need them linked properly to avoid any risk of leaks... Unless I am totally missing something with how these particular metal pieces form together?
