I'm starting to get some chips and damage to the rear fenders of my Model Y, so was reading through all of the mud flap threads here. There are quite a few of them, and I wanted to get an idea of which flaps to buy. My main stipulation is that they not be the moulded kind that sit over the fender garnish, because I've had two vehicles in the past ruined by ones like that. Those flaps rub on the garnish if they ever touch the ground and over time damaged the finish. So I knew I wanted one of the flat ones in case I needed to take them off or switch flaps in the future.
I originally bought the ZL1 Addons flaps, but just as they arrived I saw a post that an owner had them and still got significant damage. This basically left two options: Tesla's OEM flaps, and RallyArmor. Today I compared those two. The RallyArmor flaps are very nice, but I absolutely hate the giant logo. Fortunately I found that it's simply painted on and some acetone-based nail polish remover and some aggressive rubbing takes it right off with no damage whatsoever (see pics).
The Tesla flaps:
The Tesla flaps:
- Are very slightly moulded, but not enough to rub on or come up around the outer garnish. The garnish won't be ruined over time like the ones that wrap around and rub. This is great.
- They sit very low to the ground, and don't come up very high.
- They match the design of the car really well.
- Installs with 2 new plastic press-in rivets. You can install them in less than 10 minutes.
- Sit quite a bit further off the ground. Maybe 1.5" at the lowest point. It was hard to get a good comparative measurement because no tapes I could find would stick to the RA flaps to test fit and measure. They probably won't rub over every little bump like the OEM ones..
- Stick out to the side a bit further.
- Look ok (with the logo removed). They're shiny instead of matte, which I would have preferred, but otherwise look and feel great.
- Have a much more complex install with friction clips and screw-in rivets.
