Krugerrand
Meow
Worlds largest battery manufacturers down 5% on news that "just a car company" unveils plans to compete.
So market says current battery mfgs now worth less because Tesla AND Tesla worth less because ?
So market says current battery mfgs now worth less because Tesla AND Tesla worth less because ?![]()
We've pretty much entered into an age of innovation. Maybe Battery Day pushes battery makers to a new level. Or, at least pushes them to keep up with Tesla before they go the way of Ford.Today felt like what I feel like mist of happened back in those days I don't think battery cell suppliers will make the same mistakes big auto did. I get the feeling well hear some amazing partner deals come together in the next few months.
Nonsense. A while ago Elon was talking about a third North American plant on the East Coast somewhere. It only makes sense to have a close supply of lithium to that plant.IF Tesla does have a deal with Piedmont Lithium I will stop believing Elon is open and honest. It was made clear that the lithium in Nevada is more than enough for TSLA for many years to come. AND they told us they have the option to mine 10,000 acres. And they made it a point to tell us about how little environmental impact it would have on the desert.
And that having the material close to the battery plant is a significant advantage.
I use mini splits. I also have solar panels to run them with.If you want to heat your house (in Upstate NY) without burning oil or gas, is there any other option? Wait for Tesla HVAC?
(This is a serious question, I'm not disagreeing with your post.)
Of course. Once FSD is solved, it will be copied (just like the iPhone was copied). I believe Elon said in ten years everyone will have FSD. Not cheaper means the competition can undercut.The question I have is: are cheaper batteries necessary at all if FSD is solved?
A 2170 had a 1meter long anode/catode sandwich - making this tabless = 50cm travel turns into 7cm travel. = theoretical 7x improvement
The new 4680 battery - should have a 2meter (?) sandwich, tab in the middle = tab distance 100cm which turn into 8cm with tabless. = 12.5x improvement.
And the effect on heat management - Just WOW. = No more heat issues!
This was the part which I would have like to get more info on.
What effect does this have on longevity?
What effect does this have on SuperCharger rates?
What effect does this have on cooling needs? Less energy spent on heat management?
Can this be implemented on 2170 batteries from Panasonic at gigafactory?
All batteries used should be tabless asap. No need to stick with tabs.
$1/gal would make an ICE car the equivalent of a 2013 S IF the ICE car gets a real 40 mpg lifetime average. Try fifty cents/gal to be actually competitive. That puts negative profits to the fossil fuel companies. Gas can't go down low enough to compete.What if price of gas eventually drops to $1/gallon? Maybe it would have no effect on Tesla sales, IDK.
Yep, they have just been handed their going-out-of-business timeline. Superior, less expensive cars will be available in three years, and there’s nothing you can do about it.
Model 2 will have close to 300 miles range (per Elon), and it's new $50/kWh bty pack will be an LFP chemistry ("Medium" Range Tesla vehicles, per "Bty Day" presentation).
This is quite profound. Look for all 3/Y SR versions to also switch to Iron bty chemistry (LFP). The cost advantages are undeniable, and the with tabless dry process cells, their performance is as good as current NCA chemistry bty packs.
Did anybody else notice that onstage today Drew said that these new manufacturing process apply equally to Iron battery cells?
It's also important notice that Elon said Iron battery's have 50-60% of the range of nickel batteries. But the total stack of Tesla bty manufacturing innovations add 56% to the range of a vehicle (per the "Bty Day" slide).
I think this settles it: in the future, Tesla Std Rge (SR) vehicles will come with Iron (LFP) based chemistry, and will cost about $50/kWh.
This is amazing progress. First out in $25K Model 2 in 3 years? I think that'll be the Berlin car. Shanghai or a new plant in China would be the logical place to build the Model 1 "World Car".
Cheers!
Goldman Sachs also raised pt to $400.
This may be a stupid question, but can you show how that math works (in a simple way)? I would not know where to start.
But why does it look like the shingles are only on the outside of the rolled up can? Wouldn't they spiral inwards all the way? Or am I not understanding what I'm looking at?
A lot of the advances can be applied independently. They could potentially make tabless 2170s with the current chemistry.IIRC, during the presentation they stated the electrical path was reduced from 250 mm to 50 mm or 5X.
The structural pack slides seems to be using Model Y as illustrations, so that means the plan for new cells are not just for CyberTruck and Semi.
This makes me think the reason why Elon jumps in to say the dry tech is not “mass production” ready for a year, is to avoid Osborne Model Y, it doesn’t necessarily mean there is any uncertainty in getting it polished and ready when time comes.
So the 1-year timeline give people the impression that it would come to Model Y only after the Giga Berlin version, no reason to wait now.
So, I am expecting sometime from now till next September they would announce the new cell line is producing at full capacity over night, no real ramping, rather a step change.
I mean you either get the yield high enough or still too low, no need to produce more than test batches before that, and no reason to produce at lower throughput after, right?
Ok now I am spreading a theory that could Osborne Model Y, I will show myself out.
