lex-database-1 | 2023-10-17 20:44:03.207 UTC [1] LOG: server process (PID 10380) was terminated by signal 11: Segmentation fault
lex-database-1 | 2023-10-17 20:44:03.207 UTC [1] DETAIL: Failed process was running: SELECT s0."drive_id" FROM (SELECT sp0."drive_id" AS "drive_id", count(*) FILTER (WHERE NOT (sp0."odometer" IS NULL) AND (sp0."ideal_battery_range_km" IS NULL)) AS "streamed_count" FROM "positions" AS sp0 WHERE (NOT (sp0."drive_id" IS NULL)) GROUP BY sp0."drive_id") AS s0 WHERE (s0."streamed_count" = 0)
lex-database-1 | 2023-10-17 20:44:03.207 UTC [1] LOG: terminating any other active server processes
lex-database-1 | 2023-10-17 20:44:03.272 UTC [10395] LOG: PID 10384 in cancel request did not match any process
lex-database-1 | 2023-10-17 20:44:03.291 UTC [10396] LOG: PID 10386 in cancel request did not match any process
lex-database-1 | 2023-10-17 20:44:03.307 UTC [10397] FATAL: the database system is in recovery mode
lex-database-1 | 2023-10-17 20:44:03.317 UTC [10398] FATAL: the database system is in recovery mode
lex-database-1 | 2023-10-17 20:44:03.351 UTC [10399] FATAL: the database system is in recovery mode
lex-database-1 | 2023-10-17 20:44:03.515 UTC [1] LOG: all server processes terminated; reinitializing
lex-database-1 | 2023-10-17 20:44:07.787 UTC [10400] LOG: database system was interrupted; last known up at 2023-10-17 20:43:28 UTC
lex-database-1 | 2023-10-17 20:44:07.789 UTC [10401] LOG: PID 10385 in cancel request did not match any process
lex-database-1 | 2023-10-17 20:44:07.793 UTC [10402] LOG: PID 10383 in cancel request did not match any process
lex-database-1 | 2023-10-17 20:44:07.805 UTC [10404] LOG: PID 10381 in cancel request did not match any process
lex-database-1 | 2023-10-17 20:44:07.807 UTC [10403] LOG: PID 10382 in cancel request did not match any process
lex-database-1 | 2023-10-17 20:44:07.810 UTC [10405] FATAL: the database system is in recovery mode
lex-database-1 | 2023-10-17 20:44:07.830 UTC [10407] LOG: PID 10393 in cancel request did not match any process
lex-database-1 | 2023-10-17 20:44:07.833 UTC [10408] LOG: PID 10387 in cancel request did not match any process
lex-database-1 | 2023-10-17 20:44:07.837 UTC [10410] FATAL: the database system is in recovery mode
lex-database-1 | 2023-10-17 20:44:07.841 UTC [10409] FATAL: the database system is in recovery mode
lex-database-1 | 2023-10-17 20:44:07.851 UTC [10406] LOG: PID 10389 in cancel request did not match any process
lex-database-1 | 2023-10-17 20:44:07.866 UTC [10411] FATAL: the database system is in recovery mode
lex-database-1 | 2023-10-17 20:44:07.883 UTC [10412] FATAL: the database system is in recovery mode
lex-database-1 | 2023-10-17 20:44:07.895 UTC [10413] FATAL: the database system is in recovery mode
lex-database-1 | 2023-10-17 20:44:07.905 UTC [10414] FATAL: the database system is in recovery mode
lex-database-1 | 2023-10-17 20:44:07.911 UTC [10417] FATAL: the database system is in recovery mode
lex-database-1 | 2023-10-17 20:44:07.915 UTC [10416] FATAL: the database system is in recovery mode
lex-database-1 | 2023-10-17 20:44:07.924 UTC [10415] FATAL: the database system is in recovery mode
lex-database-1 | 2023-10-17 20:44:08.113 UTC [10400] LOG: database system was not properly shut down; automatic recovery in progress
lex-database-1 | 2023-10-17 20:44:08.155 UTC [10400] LOG: redo starts at 0/E5746510
lex-database-1 | 2023-10-17 20:44:08.155 UTC [10400] LOG: invalid record length at 0/E5746548: wanted 24, got 0
lex-database-1 | 2023-10-17 20:44:08.155 UTC [10400] LOG: redo done at 0/E5746510 system usage: CPU: user: 0.00 s, system: 0.00 s, elapsed: 0.00 s
lex-database-1 | 2023-10-17 20:44:08.353 UTC [1] LOG: database system is ready to accept connections
lex-database-1 | 2023-10-17 20:45:28.470 UTC [1] LOG: background worker "parallel worker" (PID 10438) was terminated by signal 11: Segmentation fault
lex-database-1 | 2023-10-17 20:45:28.470 UTC [1] DETAIL: Failed process was running: SELECT s0."drive_id" FROM (SELECT sp0."drive_id" AS "drive_id", count(*) FILTER (WHERE NOT (sp0."odometer" IS NULL) AND (sp0."ideal_battery_range_km" IS NULL)) AS "streamed_count" FROM "positions" AS sp0 WHERE (NOT (sp0."drive_id" IS NULL)) GROUP BY sp0."drive_id") AS s0 WHERE (s0."streamed_count" = 0)
lex-database-1 | 2023-10-17 20:45:28.470 UTC [1] LOG: terminating any other active server processes
lex-database-1 | 2023-10-17 20:45:28.828 UTC [10441] LOG: PID 10430 in cancel request did not match any process
lex-database-1 | 2023-10-17 20:45:29.248 UTC [10442] LOG: PID 10433 in cancel request did not match any process
lex-database-1 | 2023-10-17 20:45:29.263 UTC [10443] LOG: PID 10432 in cancel request did not match any process
lex-database-1 | 2023-10-17 20:45:29.268 UTC [10444] LOG: PID 10428 in cancel request did not match any process
lex-database-1 | 2023-10-17 20:45:29.836 UTC [10445] LOG: PID 10436 in cancel request did not match any process
lex-database-1 | 2023-10-17 20:45:29.842 UTC [10446] LOG: PID 10427 in cancel request did not match any process
lex-database-1 | 2023-10-17 20:45:29.846 UTC [10447] LOG: PID 10431 in cancel request did not match any process
lex-database-1 | 2023-10-17 20:45:29.857 UTC [10448] LOG: PID 10429 in cancel request did not match any process
lex-database-1 | 2023-10-17 20:45:29.863 UTC [10449] LOG: PID 10434 in cancel request did not match any process
lex-database-1 | 2023-10-17 20:45:31.674 UTC [1] LOG: all server processes terminated; reinitializing
lex-database-1 | 2023-10-17 20:45:32.645 UTC [10450] LOG: database system was interrupted; last known up at 2023-10-17 20:44:08 UTC
lex-database-1 | 2023-10-17 20:45:32.647 UTC [10451] FATAL: the database system is in recovery mode
lex-database-1 | 2023-10-17 20:45:32.655 UTC [10452] FATAL: the database system is in recovery mode
lex-database-1 | 2023-10-17 20:45:32.658 UTC [10453] FATAL: the database system is in recovery mode
lex-database-1 | 2023-10-17 20:45:32.669 UTC [10455] FATAL: the database system is in recovery mode
lex-database-1 | 2023-10-17 20:45:32.676 UTC [10454] FATAL: the database system is in recovery mode
lex-database-1 | 2023-10-17 20:45:32.684 UTC [10456] FATAL: the database system is in recovery mode
lex-database-1 | 2023-10-17 20:45:32.689 UTC [10459] FATAL: the database system is in recovery mode
lex-database-1 | 2023-10-17 20:45:32.690 UTC [10458] FATAL: the database system is in recovery mode
lex-database-1 | 2023-10-17 20:45:32.707 UTC [10460] FATAL: the database system is in recovery mode
lex-database-1 | 2023-10-17 20:45:32.708 UTC [10457] FATAL: the database system is in recovery mode
lex-database-1 | 2023-10-17 20:45:32.896 UTC [10450] LOG: database system was not properly shut down; automatic recovery in progress
lex-database-1 | 2023-10-17 20:45:32.924 UTC [10450] LOG: redo starts at 0/E57465C0
lex-database-1 | 2023-10-17 20:45:32.936 UTC [10450] LOG: invalid record length at 0/E5748500: wanted 24, got 0
lex-database-1 | 2023-10-17 20:45:32.936 UTC [10450] LOG: redo done at 0/E57484C8 system usage: CPU: user: 0.00 s, system: 0.00 s, elapsed: 0.01 s
lex-database-1 | 2023-10-17 20:45:33.132 UTC [1] LOG: database system is ready to accept connections
