Thanks for the suggestion. I put a post on there yesterday afternoon and so far zero responses!You might have better luck on a square space forum.
Mine auto updates, just checked and it's on this build and looks OK at quick glance.Anyone tried v1.29.1 yet - thought I'd ask first as I'm chicken
I’ve obviously missed a trick here, how do you make it auto- update? (spot the unix noob!)Mine auto updates, just checked and it's on this build and looks OK at quick glance.
You google "how do I auto update docker images"I’ve obviously missed a trick here, how do you make it auto- update? (spot the unix noob!)
So I'm using docker-compose. The first one is something called Watchtower that will look for updates to containers and then pull and update them. It needs access to the docker.sock for this to work. I also have it set to only update them at 4am and only containers where I put a label on them.I’ve obviously missed a trick here, how do you make it auto- update? (spot the unix noob!)
version: "3.5"
services:
watchtower:
image: v2tec/watchtower
container_name: watchtower
restart: always
network_mode: none
volumes:
- /var/run/docker.sock:/var/run/docker.sock
command: --label-enable --schedule "0 0 4 * * *" --cleanup
environment:
- TZ=Europe/London
labels:
- "com.centurylinklabs.watchtower.enable=true"
version: "3.5"
services:
teslamate:
image: teslamate/teslamate:latest
container_name: teslamate
restart: always
labels:
database:
image: postgres:14
container_name: teslamate-db
restart: always
labels:
grafana:
image: teslamate/grafana:latest
container_name: teslamate-grafana
restart: always
labels:
mosquitto:
image: eclipse-mosquitto:2
container_name: teslamate-mosquitto
restart: always
labels:
EveryoneI just updated my vehicle to 2024.14.8 and now TeslaMate is showing the vehicle as offline instead of asleep.
Anyone else?
Everyone
I just had a look through my Teslamate States history & most of the asleeps are shown as offline. However, there was one a couple of nights ago that was shown as asleep. Looks like a glitch then. It's weird because the Tesla app can tell the difference between asleep & offline, so it's being reported, just not to the public-facing (private) API.Not sure if it's a blip but tonight the status just went back to asleep again
This is working well & I've followed instructions above for my other query to add a button to the dashboards. However, adding this dashboard to the list seems to have thrown off a couple of other things:I have created Teslamate dashboard for my personal use which focuses on speed and temperature related statistics. There are few options on the top of the dashboard to finetune the panels, selected date range also affects the panel data.
There won't be. The Teslamate page only shows the built-in dashboards. You will see it in the dashboards drop down on GRafana if you've followed the above.This is working well & I've followed instructions above for my other query to add a button to the dashboards. However, adding this dashboard to the list seems to have thrown off a couple of other things:
(1) On the Teslamate screen, there's no Dashboard link to this particular dashboard.
Noobs should look at the Github page in the first instance(2) On the Teslamate screen, the link to the Statistics dashboard no longer works.
This particular noob has tried to navigate Github before & got hopelessly lost! I thought this was related to the installation of the new dashboard, but forgot that I had updated Teslamate at some stage too. Thank you!Noobs should look at the Github page in the first instance
I use a little known website to do my searching. It begins with a GThis particular noob has tried to navigate Github before & got hopelessly lost! I thought this was related to the installation of the new dashboard, but forgot that I had updated Teslamate at some stage too. Thank you!
Wait. I know! Oh no I don’t. I’ll try to find it. Let me Google that.I use a little known website to do my searching. It begins with a G
Is your OCD not bothered if it's marked asleep when it's really offline?When I get some time and if I can decipher the code I'm hoping to fork it and add an option to "treat offline as asleep" (like TeslaFi has). My OCD is bad with it always showing "offline" now, when I know it isn't.
I’m getting a combination of offline and asleep. I have no idea what determines which one to display.When I get some time and if I can decipher the code I'm hoping to fork it and add an option to "treat offline as asleep" (like TeslaFi has). My OCD is bad with it always showing "offline" now, when I know it isn't.
