got to this bit and have a question:@Durzel - do you know what version of Debian you are running? I have managed to get this working fine for v9, but for 10 the lets encrypt just doesn't work! -
@davidmc @simon.c - be interested to see if the below works for you?
This is what I did to make it work on v9
Create your free tier GCP instance:
Create Micro instance, enabling http and https (tick boxes) Debian 9, disk size 30gb: How to set up a free micro VPS on Google Cloud Platform
Setting up subdomains:
Create two subdomains for your domain (teslamate + grafana) and point the A NAME records to your public IP of the Micro VM
Wait for the DNS to propagate:
After creating the ANAME records, you will need to wait until the DNS has propagated, you can test this by pinging teslamate.YOURDOMAIN, when it comes back with the GCP IP you've put in, you're good to proceed.
Docker install
Open SSH (browser is fine from the VM screen)
Run the following commands;
sudo apt update
sudo apt install apt-transport-https ca-certificates curl software-properties-common gnupg2
curl -fsSL https://download.docker.com/linux/debian/gpg | sudo apt-key add -
sudo add-apt-repository "deb [arch=amd64] Index of linux/debian/ $(lsb_release -cs) stable"
sudo apt update
sudo apt install docker-ce
sudo usermod -aG docker $USER
Docker compose install
sudo curl -L https://github.com/docker/compose/releases/download/1.26.1/docker-compose-`uname -s`-`uname -m` -o /usr/local/bin/docker-compose
sudo chmod +x /usr/local/bin/docker-compose
Now follow the instructions on TeslaMate: Advanced install with Traefik, Let's Encrypt & HTTP Basic Auth | TeslaMate
Launch with sudo docker-compose up
Once you've confirmed it works without errors, you can Ctrl+C to quit the compose session and restart it with docker-compose up -d
I have created a domain name (www.ionos.co.uk) for £1 for a year, then it allows me to setup sub domains to which i now have 2. 1 for grafana & the other is teslamate.
I have my external ip from google and setup the VM instance (not ssh'd in yet).
where do i put the ip? im assuming i setup a CNAME (under the DNS option) against each (grafana & teslamate) and input the ip in there? options shown below:
DESTINATION OPTIONS
DNS ADD OPTIONS
CNAME shows this
