Looking at some of the threads open on github and for other apps using the API it does seem a bit spotty. Doesn't look like a quick fix. Might be the beginning of the end unless you have deep pockets to cough up for some form of paid version of the fleet APIMine is working fine, but I'm still on 1.28.4
Maybe I missed something, but I it looks like if you use that that you only get updates once per minute. Which would mean you lose a lot of data, and that tracking trips would not be very accurate/good.v1.29.2 is now available and a new feature is in development:
Dynamic endpoints and token to use official Tesla API (self-hosted or from third party provider)
Tesla provides a self hosted web server that implements the vehicle API as one item in this github:(ie. how do we self host)
Just entered a value for a geofence and cleared the value for the geofence on 1.29.2 - no issues. Running a standard Docker configuration.Octopus rates changed today so I've been trying to update my Cost per kWh in my home geofence using the UI.
When I enter the new rate and click save, then continue to ignore adding retrospective costs to null charging sessions, the page refreshes and the change to the rate appears not to save.
Just looking at the browser logs and can't see anything in the console or network log.
I'm running the latest version.
Anyone else not able to update a cost for a geofenced location?
I'm seeing this as well, and embarrassingly, I had this before (TeslaMate [megathread]), and I also fixed it...Octopus rates changed today so I've been trying to update my Cost per kWh in my home geofence using the UI.
OK, seems like there could be an issue (Edit Geo-Fence Charge Cost not saving · teslamate-org teslamate · Discussion #3889), so I made the change in the database as detailed in this post.I'm seeing this as well, and embarrassingly, I had this before (TeslaMate [megathread]), and I also fixed it...
But I can't remember how
What value are you trying to update the geofence too? Wondering if there’s a limitation in the amount of digits after the decimal.OK, seems like there could be an issue (Edit Geo-Fence Charge Cost not saving · teslamate-org teslamate · Discussion #3889), so I made the change in the database as detailed in this post.
I think it is this ^^^I suspect that the issue is a timeout issue when the database has gotten larger... I just manually updated the database for my change...
Home will only have one entry in the geofences table which is what you are trying to update. You would only run into issues if you were trying to update previous charging sessions. IIRC from the teslamate geofence page you can only update sessions at a particular location if they have no existing cost.I think it is this ^^^
As adding and/editing a new location is fine, but ‘Home’ would have LOTS of entries after. 4 years…
there is Google free tier...Apologies for OT, but which hosting companies are people currently using to host TeslaMate?
Iirc digitalocean was the host of choice.
I’m not interested in self hosting on Pi etc and TBH I’m not actually looking at hosting TeslaMate either but just something that may have similar requirements and I don’t have to go to Microsoft and give them my open wallet.
If supported containers and persistent storage and/or basic database, even better. Doesn’t need much RAM, probably <= 512MB would suffice if it had native container support. Minimal network and CPU too. Just host a small angular website a couple of API’s and maybe basic access to an identity server for a nominal monthly amount.
Thought DigitalOcean’s IPs were blocked from Tesla’s servers? Meaning your tokens will not refresh.Apologies for OT, but which hosting companies are people currently using to host TeslaMate?
If supported containers and persistent storage and/or basic database, even better. Doesn’t need much RAM, probably <= 512MB would suffice if it had native container support. Minimal network and CPU too. Just for hosting a small angular website a couple of API’s, maybe small database for a nominal monthly amount.
