I understand the need to limit it to EVs but in reality it will be limited to newly-built Teslas. The logistics and mechanics of retrofitting those wheels are not going to be so easy that it'll cost only $300. Literally, what can you do on your car that costs $300? You can probably get your hood wrapped and that's it. Nothing that you would need to entrust with the safety of your vehicle is a $300 retrofit.
If that is the way it is, that is on the other OEMs, not Tesla. Same as the Supercharger network, others can join, they just choose not to.
$300 was a wild guess, but it need not be super expensive. A tow hitch is arguably more critical than guide wheels and costs $400, so it might run $1k.
$80 $17 a month over 5 years. Having a guaranteed available skate would have to cost more than that.
Sure, skates are great from a system control point of view. However, they would also be the limit to system capacity. Only 1,000 skates? Then only 1,000 cars at a time. Everyone heading out of town? Need to wait till the skates return to reuse. Not efficient. It also removes the battery and motor manufacturing capacity from the EV side of things.
Say a skate is 40kWh and an EV is 80kWh. 960 kWh gets you 12 EVs, or 8 EVs plus skates.
On the contrary, our family would definitely benefit from something like the Loop. I was really looking forward to it when it made more sense to me with skates. If they ever build an East Bay to SF specific Loop then we would look into it for sure.
Gotcha, so you are in the passing through case. I can see why skates would appeal to that use case. Other than trying it out ahead of time, any reason you would not want to have a loop express lane available to take instead of a surface route?
But if a car runs out of charge on a surface street it just gets stuck in one of many lanes or is pulled over onto the shoulder. Unless Loop has many tunnels on the same routes and can easily re-route cars between those tunnels, a car breaking down or running out of charge in the Loop is a massive failure point. It'll shut down the whole system. It's like when a BART train gets stuck in the city. Since it's the singular path for every train line, it shuts the whole system down in that direction.
Loop would have more than one track in a direction (worst case, go half duplex in one tunnel) So a single failure does not have the same impact as with a subway failure or Amtrak's crossings issues. Reversing a vehicle may be an issue...
If you take a bus, you are at the mercy of all other drivers on the route and their cars. On the subway, you have points of delay also. Someone standing in the door will stop the train and delay those behind it , along with people on the tracks. It is not a common thing, but it is a thing.
Sure, in the idealized case, there would be no breakdowns, but transport systems already operate with acceptance that a crash stops traffic.
Two lane roads are all single point of failure, Mackinaw bridge is 5 miles of no gas stations, Overseas Highway has a 20 mile stretch of no stopping points. Admittedly less traveled, but usable. Interstates are one pile up or fire from stoppage.
A properly maintained car should be as reliable as a skate. Possibly more since personal cars are likely treated nicer than 3rd party car movers.
I just don't see how mixing system managed vehicles and random consumer vehicles together is a good way to assure clear and expedient travel. The benefit of the skate system is that it centralizes the management and allows them to build to their specific need. Also, slower EVs will slow down the whole system. Driving a Chevy Bolt on retrofitted bumper wheels will slow down everyone in the tunnel. Hardly any EV right now can sustain the purported 150mph for any reasonable distance. So will everyone just have to slow down to 60mph as some people are trying to preserve their charge?
With multiple tracks are different speeds the impact of a slow EV is minimized. Force Bolts to stay in the lower speed local tunnels.
All the vehicles are managed, the drivers will not be setting their speeds, the central system will via wireless link.
Even in the skate scenario, you still need an override system for the cars using it. You also need the car to get off the skate at the end. Having skates does not eliminate the issue of a car failing while in the loop, it just concentrates it at the end points (assuming the system even allows the skate to move if it loses telemetry with the car).
If they want to build a Hyperloop at some point in the future, the pod issue is going to have to be resolved anyway. So why not work on a logical solution to pod-light now?
They are different use cases until lots of people commute via hyper and still need cars. However, hyperloop can transport cars in pods for added cost.
LA level traffic is more people over short and more diffuse routes.
Edit: math error
