Fronts barely fit (I claim they do NOT fit - about 1mm clearance at best).
You may need to loosen the caliper bolt, push it inwards to allow sufficient space, and retighten. It's that tight, and I would not do it.
Appropriate 4-5mm spacer required if you want to try this; otherwise the wheel will sit on the exposed hub lip and never tighten flush to the rotor hat.
Rears do not fit.
/Thread (???) This one was from March but was resurrected today...
