If you were building an efficient(cheap) energy infrastructure from scratch today it would look considerably different than what we have in the US. So that's what's happening.
I've been thinking that "base load" is a myth for some time now. When you consider that utilities have to essentially give away electricity at night, they really don't have a base load. Some places in Texas literally have free electricity at night. How much generation capacity does it take to keep a few street lights on?
Isn't that Edisonist sacrilege on a Tesla forum.Yeah... for starters using IGBTs to convert DC=>AC is now cheaper than using transformers to step voltage AC=>AC. The entire transmission grid... if not the entire grid would likely be DC instead of AC. Even just 40 years ago stepping DC up and down was nearly impossible.
Well, everything you can do with baseload, you can do with peakers. It's just less efficient, so more expensive at high capacity factors. But you could fill in for less with peakers, as long as the primary sources are cheap enough and cover enough of demand.Thought I'd revive this old thread with a new study
100% renewable electricity is viable – Physics World
So the back-up that is required “only has to operate for several hours at a time”. They note that “base-load power stations are not suited to the task”, whereas demand management could help reduce/shift peaks and cheap OCGTs could fill in any gaps. The latter could also maintain supply over longer periods, when other back-up, such as from hydro reservoirs and batteries, was exhausted, for example “if the Dunkelflaute lasts for (say) one week in winter/summer”. Diesendorf and Elliston add that the OCGTs initially “may have to operate on fossil fuels, but in the longer term they can run on renewable fuels (e.g. biofuels, hydrogen, ammonia)”. So their prescription is very similar to that of the Brown et al. study described above.
For good measure, Diesendorf and Elliston also have a sideswipe at the view that “base-load power stations are essential”, noting that “several of the simulation studies achieve reliability with zero or negligible base-load capacity” with “flexible, dispatchable power stations and storage technologies, together with demand response” being needed, rather than inflexible base-load.
