For people with frunk install, did you regret not doing it in the trunk? How do you deal with having to bring in car for service? Looking into air suspension.
I've made it so everything is quick release, so it doesn't take too much time to remove it. Maybe 5 mins to remove it all. I'd like to move the manifold outside the frunk then it's only one line to remove everything and then the whole system will stay pressurized - maybe in the spring I'll change it up
if i were to do it all over again, i would do it in the sub trunk since i barely use it and wanted to be able to u se the frunk more
Thank you, guys, for your suggestions. Much appreciated.I do sort of miss having a frunk to use when I go grocery shopping and only have a couple bags. If you don't plan on showing off your frunk setup, then having it in the sub-trunk is def the way to go.
But definitely recommend setting up your system for easy removal of the frunk liner if you go the frunk route. I think one of the easiest ways would be to have the manifold under/behind the frunk liner. That way you only need to remove the main air line from the air tank to the manifold without having to disconnect the individual air lines to each corner.
The way I have mine setup I need to disconnect everything from my main tank and then remove the frunk liner, then mount the main tank to the main mounting points for the frunk liner. Isn't the easiest, but only takes about 15 min to do the whole process.
I'd go 20s over 21s, the 20s already leave a short sidewall as is. 21s would be like rubber bands for tires. 20>19>21Thank you, guys, for your suggestions. Much appreciated.
Lastly, if given a choice would you bag it 20s or 21s inch wheels? Pros and cons? I'm leaning towards 20s. 21s look a little too big, imo.
About damn timeSince a few weeks I've switched to bags as well, happy to join this thread.Used to have a unique setup before with Mountain Pass Performance coilovers and air cups to be able to lift the car for speed bumps, ramps and such. But that setup had some drawbacks so I made the switch to air bags. Still on the same MPP coilover dampers though so this is again a pretty unique setup. Also combined with the whole lineup of suspension parts of MPP, even the rear spring arms. Which is a first as far as I'm aware. Of course this needs custom bags and bag adapters, with the help of Kean Suspension in Belgium I was able to get this done. They supplied me the parts and I did the install myself. Ended up using the AccuAir E-Level+ management.
Have to say, very happy I went this route. Ride quality is much better, even though I still have to play around with the damper settings a bit. And of course it's great to be able to drop the car all the way and all the benefits of being able to lift.
About damn time
Just purge daily when it’s cold and you’ll be fineHaha yes it was a long time coming really..Just really wanted to get the other setup perfect first which I still did in the end. But the air suspension is so much better now, definitely makes me wonder why I didn't go with this setup sooner.
I guess my only concern is reliability long term since it's also my daily car. But will just have to wait and see if any issues arise.
Same here! Max once a monthI hardly get any moisture in my tank for some reason, perhaps I live in a good climate over here.So probably won't be an issue. I drain the tank like once every month, used to be even longer before with the air cups. My water trap that's inbetween the tank and manifold has never had anything in it. I could basically run the setup without it.
It’s funny my water trap has never seen anything either but the new setup I’m doing electronic drain valve. It’s actually pretty cool.I hardly get any moisture in my tank for some reason, perhaps I live in a good climate over here.So probably won't be an issue. I drain the tank like once every month, used to be even longer before with the air cups. My water trap that's inbetween the tank and manifold has never had anything in it. I could basically run the setup without it.
My new subtrunk setup in the Y. Having done this setup in 2 cars now…it is quieter than the frunk & you can still show it off
im trying to sell my air suspension. i have a RWD SR+. can anyone confirm that this will or will not work with the AWD LR or Performance models?
did you ever find anything about these? Im thinking of going with them since they are local to me..Has anyone had experience with flyyair struts? How are they compared to UAS and airlift
