I have touched the subject sometines.
It is easy to dig a whole that make the answer not very short and also get everlobg discussions about the base for the strategy.
Charging to 100% is not very bad, even for NCA or NMC.
The forum truth is to not let the car stand long time if charged to 100%.
While it is true that letting it stand at 100% cause more calendar aging/degradation than if it stands at 30% it is not at all catastrofic. In some cases 100% is less bad than 75-85%.
When being above a plateau, the degradation is more or less the same, unless in extremely high temperatures.
As we can se, it is about the same degradation above the “step”. And yes, the calendar aging hapoens even if we use the car, and for most people it isnot used for 22hours a day. The graphs above is valid for us and our EV’s!
The above in memory, 100% is not really worse than 70-90%.
That research report has a few years but we have no data telling us that new LFP is taking a lesser hit than before. Perhaps/probably the rate is slightly slower than in the chart but the basic principle probably still is valid.
I would charge to 100% once a week, but I would have it at lower SOC the other days, 50-70% depending on the minimum SOC covering my needs.
I would charge late (finished shortly before the drive).
We have some data, but as the LFP cars have a hard time judging the true SOC below 100% I would guess that its at least slightly harder for the BMS to judge the capacity as well, as different true SOC + the difference in energy in/ out is part of the calculation.
The charts for LFP’s at teslalogger.de show us that the LFP degradation is about the same or slightly less than other teslas (NCA mainly). We know the LFPs is non sensitive to large cycles and can do many of them so the degradation we see is more or less calendar aging only.
It probably is per above
Thanks! Solid info. I didn’t realize LFP wasn’t sensitive to large cycles. That’s good, because I drive my car very little, so my strategy has been to not charge every time I’m home, but just leave it at what charge it’s at until it get down to around 20-30%, and then just before the next time I need it, charge to 100% and repeat. This leaves me only charging to 100% about once every two weeks. Was wondering if I shouldn’t charge to 100% every time and only charge to 60% or 70% in between to reduce average cycle size.
